I am putting an AE101 ST into a Lotus Europa and need a Toyota pressure plate for the setup. I have the ST flywheel but cannot seem to find the relevant P/N for the pressure plate only or a compatible part.  Need help,
Thanks
Astrobase
						AE101 clutch pressure plate
Re: AE101 clutch pressure plate
Thanks, that was helpful
Hmmm too bad, I have a TRD pressure plate for the GZE available but that won't help you with at ST flywheel...
