Postby jondee86 » Thu Sep 25, 2014 5:54 pm
			In front you probably need to decide if you are going to work with the
stock suspension, or use some kind of aftermarket coilover. Because if
you use a coilover that comes with spindles, that takes care of the whole
strut assembly. Then all you need to find are some lower control arms,
brakes, steering and tension arms. Most likely you will want to upgrade
the brakes from stock GTS to something better. If you do, it will mean
you don't have to try and find GTS brakes which have mostly all gone
to SR5 upgrades.
