Smoking battery +
ae86xy
Smoking battery +
Postby ae86xy » Sat Nov 08, 2014 9:53 am
Its a 86 gts
Heres my problem i was driving for 15m. Then i saw the CEL flash then all of a sudden the car died and pop the hood saw the battery + all smoking and the ground all melted pls. Help me out what could be the issue here
Re: Smoking battery +
Postby jondee86 » Sat Nov 08, 2014 4:51 pm
Sounds like you got yourself a dead short on some pretty heavy
duty wire somewhere. I'd be looking at the starter wire as most
everything else would be protected by the fuses on the positive
battery terminal connector.
Glock30
Postby Glock30 » Mon Nov 10, 2014 10:27 am
Might also want to check the wires going from the alternator to the fuses. Those wires are all in the loom and could melt a lot of things together if something goes wrong.
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
