Megan coils help.
Megan coils help.
Soooo I just picked up my coilovers. And I put the rear in but my problem now is that I can't seem to tighten up the top bolt without the shock moving with it. Tried holdin the shock. And tried holding the shock and using a impact wrench
GreenLantern
Re: Megan coils help.
What top "bolt"? There should be two nuts up top in rear from inside the trunk and one bolt holding the bottom of the strut.
I would jack up the car with the rear drooping a bit. Then I would undo the bottom bolts of each strut. Then try tightening the top nut of each strut. I think you just gotta finangle with it and it probably is just in a pickle haha.
Also- on my car there are 2 nuts at the top of the strut. One is to hold in place while you tighten the nut on top of it. Mabe this is your issue.
Good luck
Vic
Good luck
Vic
Thank you for input! I was able to get it done. Thanks club!
