T50 transmission sleeve springs
ZINCHOTRAN
Postby ZINCHOTRAN » Sun Mar 29, 2015 2:55 pm
How is everyone?
Love this forum.
Okay. I finally took out my transmission because I am tired of only having fourth gear.
It is taken apart again and I found out the transmission shop I took it to, 3 years ago, reversed the fifth gear/reverse sleeve and hub. I cleaned up the keys and I found out one of the springs that the keys ride on broke apart. I need to find one or make one. Going past 95 miles per hour on the freeway would be nice :lol:
Any and all suggestions please. My second car is 154 miles away. The spring is around 140mm long and 1.56mm thick.
Thanks for any and all helpful comments or leads to a solution.
I do know of the leen transmission and the W-series of transmissions. If I need to swap that'll be next yet far into the future Money is tight. For now I just want to complete this T50.
Update:
April 8, 2015
I replaced the C spring and put the T50 back together. After the RTV cures tonight, I will install the T50 tomorrow after work. I will update again after I test drive it.
davew7
Re: T50 transmission sleeve springs
Postby davew7 » Mon Mar 30, 2015 5:19 am
Are you looking for the large "C" shaped spring that holds the keys in place for 5th/Rev gear. P/N 33371-14040
If so send PM. Dave
ZINCHOTRAN
Postby ZINCHOTRAN » Mon Mar 30, 2015 12:26 pm
I sent a PM.
ZINCHOTRAN
Postby ZINCHOTRAN » Mon Apr 06, 2015 2:24 pm
Davew7,
Thanks again for the parts. She will rise again and go faster too. :)
