Any info on these pistons?
Cortina69
Postby Cortina69 » Fri Apr 10, 2015 6:06 am
Gents,
Just seen these, but the only info I have is that they are high compression out of a red top. Can anyone shed anymore light on what they are etc etc...
Many thanks
Re: Any info on these pistons?
Postby oldeskewltoy » Fri Apr 10, 2015 8:33 am
Cortina69 wrote:Gents,
Many thanks
maybe if we could read the labels.... from what I see they are 1990+ 4AGE high comp (smallport) pistons. I can't help you with their bore
Cortina69
Postby Cortina69 » Fri Apr 10, 2015 8:47 am
If they were standard bore, what compression would we be looking at?
Postby oldeskewltoy » Fri Apr 10, 2015 11:15 am
Cortina69 wrote:If they were standard bore, what compression would we be looking at?
in a completely stock 4AGE... 10.3 to 1 Lower the deck, or a thinner head gasket and the comp goes up
Rogue-AE95
Postby Rogue-AE95 » Fri Apr 10, 2015 2:33 pm
What part number are those pistons? Is the brand on that box behind them, Enginetech?
Cortina69
Postby Cortina69 » Sat Apr 11, 2015 12:09 am
The make are Aisin? Running a compression of 10-3-1. Is this right?
Rogue-AE95
Postby Rogue-AE95 » Sat Apr 11, 2015 8:47 am
Looking closer at your pic, they look like used pistons. The tops look like they're coated, so they're likely OEM. And 10.3:1 is correct if those came out of a "redtop," or a better identifier, a smallport.
