what 5 or 6 speed is compatible.
I would like to know which 5 or 6 speed manual transmissions are compatible for an 1988 corolla wagon all-trac since its 4wd what can I use it is automatic currently and and going to convert it to stick. Any help appreciated.
corolla4dr4agze
Re: what 5 or 6 speed is compatible.
If you are keeping the 4afe stock engine, then your only option is a 5spd manual from another all-trac wagon. Trans code is E57F5. I am working a a hybrid using parts from a newer narrow E series trans. More on this over at alltracwagon.net
Check out my ride viewtopic.php?f=7&t=4527
Check out my build http://www.alltracwagon.net/forum/m-1347147405/
