OST-035: Silver Blaze
Postby oldeskewltoy » Mon Sep 28, 2015 4:51 pm
My client dropped off his 20V silvertop for a bit of massaging
Mix in Toda springs, and Tomei Poncams, and stir to 7800 rpm.... for now.... :D
More to come.... :D
Bempa
Re: OST-035: Silver Blaze
Postby Bempa » Tue Sep 29, 2015 6:28 am
Your threads are very inspiring. It all started with a google search in AE95 and i found your Grunt thread. After that I could not stop reading your threads, you do such i great job and you are kind enough to show it. But you might have to ship over your Alltrac to Sweden so you could sell it to me ;)
Skickat från min D5803 via Tapatalk
Dream86
Postby Dream86 » Tue Sep 29, 2015 10:02 am
I second that. Great knowledge and skill. Pleasure to read. Keep up your awesome work!
Postby oldeskewltoy » Tue Sep 29, 2015 2:51 pm
Thank you for the kind words.... from both of you :D
Grunt is not for sale.... my wife would be greatly upset if I sold it, she has used it for the past year, and grown quite fond of it.
so proceeding.....
Although the head looks pretty clean, and it is(was), the exhaust ports are still moderately heavy with carbon, so for that reason, and I want to make sure the head is capable, I've sent it out to get cleaned and pressure checked. I'm also having it checked for flatness.
A bit more about this build.....
My client will be using Toda AE101 pistons
they carry a 4.6cc dome, static compression will be around 12 to 1 while using a .8mm head gasket - as per Toda. He will also be running Toda's AE101 valve springs - good to 11 mm of lift
He will be using 20V Poncams
more to come.... :D
Postby oldeskewltoy » Wed Sep 30, 2015 10:31 am
from another forum wrote:Thanks for the cam card.
(responding to "having it checked for flatness") - Feeling sorry or tossing them a bone for goodwill?
How about a hardness test, the Toymods guys just love that BS. :smile:
client wants a bare minimum cut - .001", maybe .002" if required. the flatter the surface the lower the cut......
I've heard of testing the 7M heads... I've not heard of people checking the 4A heads....
Had to order some new equipment.... the 16V spring remover/installer doesn't fit the pockets the 20V springs fit into... so....
more to come....... :D
Bempa
Postby Bempa » Wed Sep 30, 2015 10:35 am
Is there any problem with castings since people test hardness?
Where is that tool kit from?
Postby oldeskewltoy » Wed Sep 30, 2015 11:56 am
Bempa wrote:Is there any problem with castings since people test hardness?
I've heard of testing the 7M for hardness consistancy... many.. when severely overheated (headgasket failure) would cause the head to become "softer".
BEFORE you buy that tool kit... let me make sure it will work..........
oldeskewltoy wrote:Had to order some new equipment....
actually quite a bit more.....
For the past 5 years I've used mostly Dremel motors(5), and flex shafts (4). I also was using a Black and Decker RTX (about 60% more amperage/torque) than the Dremel. I've used the RTX almost exclusively for that past 18 months, enjoying the torque advantage it offered.
Well, in the middle of OST-034 the RTX began to die. So it was finally time to really upgrade.....
I've purchased the 1/6 hp Foredom SRX, along with 2 handpieces, the larger of which you see in the above photo. For now I'm keeping the Dremel for finish work since it does still have a higher maximum rpm - useful in getting that nice finish.
More to come..... :D
Bempa
Postby Bempa » Wed Sep 30, 2015 11:44 pm
Ok, so if i understand correctly there is a chance for the head to go soft if it's badly overheated? How big is the chance ofta that?
Postby oldeskewltoy » Thu Oct 01, 2015 7:36 am
Bempa wrote:Ok, so if i understand correctly there is a chance for the head to go soft if it's badly overheated? How big is the chance ofta that?
I honestly don't know..... my experience with 7M heads is very little. For the best information, I'd look at forums with far more 7M experience. As far as "A" engines are, I've not heard of it ever being a problem
Bempa
Postby Bempa » Thu Oct 01, 2015 8:37 am
I have never heard about it before. But i do got a story about Toyota cylinderheads, as tinkering with Toyota is very rare in Sweden, the machineshop i went to hade never shaved a Toyota head, (they manufactured stuff for the industry, but I knew he did some car stuff on the side just for the fun of it) The guy said after he had done the job, that it was by far the best aluminium quality in a cylinder head he had seen. It was a 2nd gen 3sge head.
Postby oldeskewltoy » Wed Oct 07, 2015 11:34 am
from another forum wrote:That's a nice looking head! :D
It will only get better looking........
Well... that took a week??? to get this thing cleaned, and pressure checked.... I'm guessing they were busy???? :roll:
ANYWAY..... the head checks out, and it is flat! this means a cut of .002" or less will provide the mating surface for a good metal gasket seal.
This head will be getting half a valve job.... yep, half a valve job!
The intake seats, already with 3 angles, will get a very fine (400 grit) lap in, while the exhausts will get a full on 3 angle.
and I've begun the port work.... the intake side is all new, like OST-034 was. Buuut... unlike OST-034, there is a fair amount of port to bowl transition blending required. As to how much.... I'm following OST's first rule of porting... do no harm, so could I take more.... maybe.....
now as far as the exhaust goes.... Image
but the exhaust I've got well in hand.... Image
Here is a view down(up?) the bowls to the roof... notice the ledge(angry eyebrows)...???
Anger removed... and all without Botox....
and a view at the short radius, and the transition to the port from the bowls
more to come..... :mrgreen:
Postby oldeskewltoy » Wed Oct 07, 2015 12:40 pm
Silvertop chamber volume.........
more to come...... :D
Postby oldeskewltoy » Wed Oct 07, 2015 1:14 pm
oldeskewltoy wrote:A bit more about this build.....
oldeskewltoy wrote:Silvertop chamber volume.........
My math comes out to a few hundredths of a point different then Toda's, but for sake of chamber volume confirmation... 36cc seems to be the Silvertop's chamber volume Image
Postby oldeskewltoy » Fri Oct 09, 2015 8:39 am
oldeskewltoy wrote:Anger removed... and all without Botox....
anger removal from a different perspective....
101_gze
Postby 101_gze » Sat Oct 10, 2015 1:12 am
Wow Dan. Thats really cool the way you label and number the seat angles like that! I mean, awesome work. WHERE DID YOU GET THAT IDEA??? :roll: I'm sure you'll give props where props are due right?
Also, this comment:
Toymods guys love that BS?
What are you actually quoting here? Who are you quoting and what forum is it from, I know you love quoting other forums, but this does not make any sense?
Great to be able to chat to you here, without any static,
Awaiting your reply.
Postby oldeskewltoy » Mon Oct 12, 2015 4:58 pm
As to props for marking the 3 angles?? I've been doing that for a few years, and I'm sure I saw someone else post it that way a long time ago.....originally, likely in some old car mag... and it was likely an article on Smokey Yunick... or some other engine builder.
as to the quote, the person quoted is also a member here, if he chooses to answer, he can, his original quote is here - http://www.mr2oc.com/showpost.php?p=6352361&postcount=5
Began the day @ 2 down 2 to go.....
Now @ 3 down 1 to go....
and comparing the yet to have begun, to the mostly finished...
Postby oldeskewltoy » Wed Oct 14, 2015 12:59 pm
working the final port/bowl of this head...
and now with the head ready to go back and get it's exhaust only 3 angle, and a minimum re-surfacing - .001"
Postby oldeskewltoy » Wed Oct 21, 2015 11:39 am
Back from the machine shop... surface was machined .002", isn't that pretty, and ready to accept a metal gasket.
Now carrying the exhaust 3 angle(bowl closest), and as you can see the intake 3 angle is still good, so I used a tiny bit of lapping paste to get the intake seats and valves mated
Clover lapping paste on left, Permetex/NAPA valve grinding compound on right... think of the Clover as a polish
that polish helped reveal..... a tiny bit more performance may be available with a back cut on the intakes. That is for another day/head.
the red arrow is pointing to the top of the seat-valve contact point, so the dotted green lines represents a bit of room for a simple, clean back cut.
Finally, my client asked me if I could do something to better accommodate his use of ARP studs....
Look back at the first pic in this post to see the bolt hole before.....
more to come..... :D
Postby oldeskewltoy » Wed Oct 21, 2015 1:00 pm
from another forum wrote:I enjoy reading the detail in your threads but not being an engine builder guy I probably understand less than half of what you're saying...:confused:
What is the purpose/benefit of the multiple angles on the valve seats? Radiusing the openings for better flow?
Does the type of spark plug used during chamber volume measurement vary the reading? Or is something else used to plug the hole during measurement?
I use an epoxy filled spark plug with the ground electrode removed. This gives me a consistent measure. Yes - a "colder" plug will often times have a bit more room around the positive electrode, effectively increasing the chambers volume.
multiple angle valve seats - Air flowing past with minimal eddy currents. A steep angle on any of these faces and tiny eddy currents can cause poorer flow.
I've recently heard about a 7 angle... yes 7 angle valve seats... can't find a pic, but here is a 5 angle.... http://www.d-series.org/forums/attachments/engine-building/22492d1258097816-3-angle-valve-job-q-5angle.jpg
now if your machinist has the capability, this is what is often the top of the line for flow past the valve, it is a radius valve job - http://rennlist.com/forums/attachments/928-forum/904333-port-and-polish-by-comiittee-thread-cool-pics-throughout-pic3.jpg the only flat surface on there is the small area where the valve contacts the seat, the rest is a radius
Postby oldeskewltoy » Fri Oct 23, 2015 5:08 pm
oldeskewltoy wrote:another new tool on the way..........
I realized that I needed a new support system to assemble this head...
and so now that the port work, the valve job and the machine work are complete, assembly follows.......
the nut driver under the head was my seal installation driver today ;)
The 2nd new tool can be seen supporting the head.
so here is the 1st new tool (9/30/2015 post) up close, in "action"
and fitting the last valve....
assembled.... waiting for its owner.
