Engine not running 100% HELP!!! (4AGE NOOB)
4age_lvr
Postby 4age_lvr » Mon Nov 09, 2015 12:53 am
engine started running weird out of the blue
not sure if its a fuel system problem
ignition system prob
ecu
injector prob
I changed the distributor cap and rotor and no changes. Car used to run 100% never had a problem with it, super bummed can't figure it out.
Runs like its got half the power or not really like its bogging.
Engine has good compression.
HELP!!!
Re: Engine not running 100% HELP!!! (4AGE NOOB)
Postby yoshimitsuspeed » Mon Nov 09, 2015 10:01 am
Do a full tuneup. plugs, wires, air filter, fuel filter, everything unless it has been done very recently. If so inspect it closely.
While it's ldling pull one spark plug wire at a time. See if the idle drops more on some cylinders than others. If so you have problems with specific cylinders. If not then you have a general problem that's affecting them all.
Start going through the diagnostics and troubleshooting sections of the FSM.
gts/classic
Postby gts/classic » Mon Nov 09, 2015 7:47 pm
Pull the complete ignition out check it out thrully...
sirdeuce
Postby sirdeuce » Mon Nov 09, 2015 8:44 pm
Timing belt?
One shot, one kill.
Postby jondee86 » Mon Nov 09, 2015 9:23 pm
TVIS stuck open (hose off, solenoid not working etc) ?
Postby yoshimitsuspeed » Mon Nov 09, 2015 9:49 pm
sirdeuce wrote:Timing belt?
Wouldn't hurt to check but it should show up on a compression test.
Postby oldeskewltoy » Tue Nov 10, 2015 10:34 am
AFM car? Torn intake boot???
