Are Wheel Studs same front and back? Ae86
saiGone
Postby saiGone » Tue Dec 08, 2015 8:44 am
Hey Club,
Corolla GTS 1986
I have extended lug studs from the front wheel assembly I got from my parts car.
Can i use them on my rear? Plan on using a slim, slip on spacer.
lugs are a good 1" longer than stock. Will probably use 25mm spacers.
Thanks
Re: Are Wheel Studs same front and back? Ae86
Postby jondee86 » Tue Dec 08, 2015 11:55 am
Here is some information on the OEM studs from my AE86 (JDM spec)...
Measurements are from under the head.
All of these studs have the 14.17-14.20 knurl and will happily pull into
AE86 hubs without raising a sweat. So if your long studs pulled into
front hubs, they should work on the rear hubs.
saiGone
Postby saiGone » Tue Dec 08, 2015 2:05 pm
Thank you sir!
