Ae86 won't crank
alexis.86
Ae86 won't crank
Postby alexis.86 » Tue Mar 01, 2016 10:37 am
Hi my ae86 wont crank and i got the code 2 and 8 what could it be?
alexis.86
Re: Ae86 won't crank
Postby alexis.86 » Tue Mar 01, 2016 11:52 am
And now the code 6 appear....
Postby jondee86 » Tue Mar 01, 2016 12:08 pm
alexis.86
Postby alexis.86 » Tue Mar 01, 2016 12:16 pm
there no code 2/6/8 on this page...
Postby jondee86 » Wed Mar 02, 2016 12:24 am
Hmmm... well, that makes it pretty much useless as a reference :oops:
This should be more useful...
EDIT: Here is the version for AFM cars (USDM cars). The other one was for
non-AFM cars (JDM cars or cars with JDM ECU's). Use whichever one happens
to match up with the codes you are pulling.
SgtRauksauff
Postby SgtRauksauff » Wed Mar 02, 2016 7:24 am
No crank means your starter isn't even turning over, and that's nearly the most simple circuit on the whole car. There are only a couple things that will keep your starter from cranking the engine.
First, double-check your battery post connections, and the connections of wires to the starter. Check for corrosion/oxidation under the insulation near the connections, it can be sneaky and hide a few inches up the wire under the insulation.
Double-check your clutch switch/neutral safety switch, to make sure that it's allowing current to the starter relay clutch switch may have gotten dislodged by a foot poking around, or a floormat, or a mouse chewing wires.
With the water/air/rpm circuit signals being funky, check to make sure that you don't somehow have loose/broken/frayed wires, or a loose connector going into your ECU in the passenger footwell. I've not had the wiring apart on the AE86 to know exactly where to look, but I can easily see this whole problem being caused by one part of the harness being damaged.
good luck!
--sarge
alexis.86
Postby alexis.86 » Sat Mar 05, 2016 3:57 pm
SgtRauksauff wrote:No crank means your starter isn't even turning over, and that's nearly the most simple circuit on the whole car. There are only a couple things that will keep your starter from cranking the engine.
good luck!
--sarge
Thanks !! i'll check my wiring if it's not broken
