4agze and other engine parts
slipNslideae86
Postby slipNslideae86 » Tue Mar 15, 2016 6:27 pm
AE92 4agze ecu with wiring all converted to rwd (ran fine but hesitated at bottom end, not sure if it was a error in wiring or mechanical) including AFM, igniter, resistor, distributor and plug wires $200
4agze intake manifold $100
SC12 (outlet pipe has been modified) $150
SC14 $250
mr2 intercooler with piping setup for top mount $65
AE92 7rib block honed and cleaned and painted red $100
AE92 redtop 10.3 pistions (3) $40
Disassembled but selling together:
AE101 4agze block (empty) w/near new oil pump, near new rwd 16v water pump and water lines, oil pan with AN bung welded on the side for oil return (best if you plan for turbo)
AE92 smallport head (complete)
AE92 gze connecting rods (4)
AE92 gze 8.9 pistons (4)
AE101 gze full counter balance crankshaft polished with caps, new seals and new main and rod bearings
$550
OniKyanAE86
Re: 4agze and other engine parts
Postby OniKyanAE86 » Fri Mar 18, 2016 11:49 am
PM'd you reference the AE92 4agze ecu with wiring harness and other included parts. Also just want to make sure if it is the distributor or cam angle sensor version 4agze?
GZE_RA21
Postby GZE_RA21 » Sat Mar 19, 2016 3:42 pm
Sent you an email about some parts, won't let me PM since I'm a new member apparently.
