cam spec's question
slow_poke
cam spec's question
Postby slow_poke » Thu Apr 14, 2016 11:31 am
I'm looking for: Duration at 0.050" for both NA and SC cams. anyone have this? can i calculate this?
Here's what i found on-line:
Camshaft Calculations - Lobe Center / Duration
4AGZE SC
Intake 8/44
Exhaust 47/5
Lift 7.1mm
Your STOCK SC CAM has an Overlap of 13.00 degrees and has in Intake Duration of 232.00 degrees. The Exhaust Duration is 232.00 degrees. Your Lobe Separation Angle is 109.50 degrees. The Inlet Cam has an Installed Centerline of 108.00 degrees ATDC. The exhaust cam has an Installed Centerline of 111.00 degrees BTDC.
4AGE NA
Intake 9/51
Exhaust 51/9
Lift 7.56mm
Your NA has an Overlap of 18.00 degrees and has in Intake Duration of 240.00 degrees. The Exhaust Duration is 240.00 degrees. Your Lobe Separation Angle is 111.00 degrees. The Inlet Cam has an Installed Centerline of 111.00 degrees ATDC. The exhaust cam has an Installed Centerline of 111.00 degrees BTDC.
and here was the link where i found it....
http://www.mr2oc.com/2-mki-84-89-na-sc/ ... specs.html
thanks!
Re: cam spec's question
Postby oldeskewltoy » Thu Apr 14, 2016 11:41 am
I've been using 204 degrees @ .050" for early cams based on this listing from - http://www.cyberauto.com/index.php/ToyotaMR2AW11(85-89).txt It has been around for about 18 years.....
Web-Cam 4AG Cams. Brand new cams on new billets!
#294, 244 Deg. Duration (218@.050"), 8.18mm Lift, $399.00/pr
#577, 252 Deg. Duration (226@.050"), 8.38mm Lift, $399.00/pr
#101, 250 Deg. Duration (229@.050"), 8.89mm Lift, $499.00/pr*
(Stock: 204 Deg. Duration @ .050", 7.52mm Lift)
*with your core, 101 grind only
later cams I'm using 198 @ .050"
