4age 16/20 timing
killercam
4age 16/20 timing
Postby killercam » Fri Jun 29, 2018 3:21 pm
Need help putting the hybrid 16/20 on timing,the bottom notch not lining up. but the white dot on the timing guide lines up and spins freely! Any pics or write up on this will be appreciated :?:
16valve head on 20valve block both are fully stock no mods
Re: 4age 16/20 timing
Postby oldeskewltoy » Fri Jun 29, 2018 4:36 pm
killercam wrote:Need help putting the hybrid 16/20 on timing,the bottom notch not lining up. but the white dot on the timing guide lines up and spins freely! Any pics or write up on this will be appreciated :?:
Blacktop 20V? It has a different lower drive cog then the other engines do...
I'd get a lower timing belt pulley from another 4AG (16V, or silvertop) and try again...????
killercam
Postby killercam » Fri Jun 29, 2018 5:04 pm
Thanks for the reply I have both 16v & 20v silver top lower pulleys and timing belt!
Postby MisterJerk » Thu Jul 05, 2018 5:57 pm
I usually get email notifications for PMs.
I used everything from my 16v block. 16v oil pump, 16v lower timing sprocket and 16v crank pulley. So i could us all rwd 16v accessories and tensioner.
You can use the 20v oil pump and tensioner, modifying the rod slightly longer. But i didn't trust the hydro tensioner.
The black top 20v crank pulley, timing sprocket, are a bit thicker.
Im also running a HKS 2.0mm head gasket.
Thats all i can think of right now
Edit: i used a Blacktop 20v block, crank, pistons. Everything else is 16v. Smallport head, tvis delete, rwd intake manifold. Rwd alternator and water pump.
Changes are coming soon, as I have high comp pistons in the shed.
