40mm rods, crank and flywheel
sirdeuce
Postby sirdeuce » Sun Mar 17, 2019 3:35 pm
I have a 40mm crank and rods with a light flywheel (I believe it is 9lbs) with a new pressure plate. I have a set of ARP rod bolts that go with the rods. I also have an oil pan that was baffled and had the volume increased. I have a JDM block posted elsewhere here as well so this would be a duplicate on that. Would make a great Auto-X mill, I've had this combo in my bottom end before.
$250 for the rotating assy.
$200 for the block.
$75 for the oil pan.
Would consider some trades for cams, mild 250-260 range with 8+mm lift.
One shot, one kill.
Davegt27
Re: 40mm rods, crank and flywheel
Postby Davegt27 » Tue Mar 26, 2019 4:28 am
Do you have any pics of the parts?
Davegt27 Code One Racing
sirdeuce
Postby sirdeuce » Tue Mar 26, 2019 2:11 pm
having issues downloading pics to this site, I can send them to your phone if you like.
One shot, one kill.
