AE101 Silver Top Compressor
BlueAngel
Postby BlueAngel » Tue Jun 04, 2019 9:03 pm
Fellas,
My Air compressor decided to quit on me during this hot summer.
after pulling the part number from the compressor "Denso 142500-2300" TV12C, I am having trouble to find a replacement, I even called Denso and they said since the engine is from Japan, they don't have a replacement part and the compressor have been discontinued. Denso recommended having an experienced mechanic to pull it and try to compare it with others and find a match. As of today, I am still trying to locate one.
Does any of you guys with experience in these engines happen to know what would fit as a replacement?
any help or information will be very appreciated.
Thanks
Blue Angel
Sprite
Re: AE101 Silver Top Compressor
Postby Sprite » Fri Jun 07, 2019 6:38 am
Blue I have a compressor that I pulled off of my Silvertop since it won't fit in my engine bay. It has a slightly different part number TV12EC 442500-2220. If you think it would work we can connect via private message and work something out.
These part numbers are weird though, the Toyota diagram shows the number should be
88320-1A250 (05/1992 - 04/1993)
88320-1A340 (05/1993 - 04/1997)
but neither of those is on the unit
Rick
BlueAngel
Postby BlueAngel » Thu Jul 04, 2019 5:41 pm
Rick,
Thank you for you response.
Please check you inbox, I messaged you.
hopefully you still have the compressor available.
Thank you
Alberto
