CEL Code 6 cant figure it out :(
eightfive
Postby eightfive » Thu Nov 07, 2019 12:34 pm
Afternoon everyone,
I've been banging my head against this and trying to figure out where I need to go next. I've been trying to clear codes and finally got to one last one which is
Code 6
RPM Signal
- No NE, G signal to ECU within seeveral seconds after engine is cranked
- No NE signal to ECU when the engine speed is above 1,000 rpm
I was able to verify resistance on the female plug of about 170 which I saw is within range but not sure if I need to test male plug? Ive been hearing different things and just want to see what you guys think?
My next step is probably testing at the ECU but even there Im not sure which pins I need to be testing
Im assuming NE+ with G- and G+ with G-?
Last little tid bit is that the car runs like a champ no misfiring and has had a recent change in plugs, plug wires, cap and rotor. If I keep above 4k RPM in any gear the check engine light goes away. Any ideas?
Thanks!
https://imgur.com/a/V32oDVl
kiosk
Re: CEL Code 6 cant figure it out :(
Postby kiosk » Thu Nov 07, 2019 7:00 pm
hey glad you were finally able to post here!
viewtopic.php?f=13&t=17903#p116602
jondee86 wrote:For an AE86 error code 6 is:
Places to look:
Distributor circuit.
Distributor.
Igniter.
Starter signal circuit.
ECU.
I'd start by checking all the wiring around your distributor and igniter. Look
for broken or frayed wires, damaged plugs, shorts, burned wires. In particular
look at the wires just where they connect to the distributor which is where they
move around the most.
you can also check my sig for the diagnostic manual, page 79
eightfive
Postby eightfive » Thu Nov 07, 2019 7:37 pm
Haha thanks Kiosk! How do i test continuity if my dizzy is a two plug rather than the one plug like whats pictured?
kiosk
Postby kiosk » Thu Nov 07, 2019 8:58 pm
Oops.
Here you go
eightfive
Postby eightfive » Fri Nov 08, 2019 8:41 am
Looks like im only getting resistance from Ne+ and Ne- but nothing from the G+ or G- connector. Going to swap dizzys and see. Will update once i tackle this
