OST-064: Breathing on a 3 rib
Postby oldeskewltoy » Fri Jan 31, 2020 4:00 pm
more to come..... :D
Re: OST-064: Breathing on a 3 rib
Postby oldeskewltoy » Mon Feb 03, 2020 8:43 am
OST-064 "Cleaned"....
After getting it cleaned, I deburred the casting
And then before porting, I had it "tumbled" so the head now looks new, no discoloration do to oils, carbon, or coolants.
more to come...... :D
Postby oldeskewltoy » Thu Feb 06, 2020 1:01 pm
Work begins.... One done...
and a bit closer...
more to come.... :D
Postby oldeskewltoy » Tue Feb 11, 2020 7:41 am
oldeskewltoy wrote:
more to come.... :D
2 down....
more to come......... :D
aukword1
Postby aukword1 » Tue Feb 11, 2020 10:06 am
Great work as always! Quick question though, what does "tumbling" the head consist of? Is it similar to tumbling bullet casings?
Postby oldeskewltoy » Wed Feb 12, 2020 7:52 am
aukword1 wrote: what does "tumbling" the head consist of? Is it similar to tumbling bullet casings?
Not sure (tumbling bullet casings...???) What "tumbling" means in this case is they have a large tool - it consists of a large cabinet, with a rotisserie that you strap the head too. The cabinet is closet, and it tumbles inside the cabinet. The media used is cast zinc shot.
a bit further yesterday..... 3 down....
and an up close view inside on the exhaust side....
aukword1
Postby aukword1 » Wed Feb 12, 2020 11:16 am
Ah, thanks for the clarification. It's actually very similar to tumbling bullet casings for reloading ammunition except its a different type of media used. Very cool!
Postby oldeskewltoy » Fri Feb 14, 2020 6:40 pm
oldeskewltoy wrote:
4 down....
Postby oldeskewltoy » Wed Mar 11, 2020 3:07 pm
and the internals.......
crank on right has wankered key groove in snout
Postby oldeskewltoy » Wed Mar 18, 2020 5:32 pm
everything is back in my hands for final assembly....
head, with fresh valve job (machined .008")...
along with assembled short block - those are Molnar Tech 40/20 H- beam rods
Does anyone see the remnants of a problem in the deck???
It took a great deal of decking to get the block suitable to accept a metal gasket.... so much so that our deck is now .018" (piston above the deck!)
The "fix", Cometic C4166-051, that should set the squish back to .033", or just a tick above .8mm.......
More to come..... :D
Postby oldeskewltoy » Wed Mar 25, 2020 8:20 am
[QUOTE=oldeskewltoy;1110545]
More to come..... :D[/QUOTE]
Did(Do) you see it????
How about if I point it out.......
A little extra clearance at the bottom of the bores to make sure the new rods clear during rotation
As often happens when you mix valves from one head, with a different head... and new cams......
Getting the valves tipped so that they are in the middle of my shim bank sizes so I can set valve clearance to the thousandth(.001")
Postby oldeskewltoy » Wed Mar 25, 2020 8:22 am
oldeskewltoy wrote:along with assembled short block - those are Molnar Tech 40/20 H- beam rods
Postby oldeskewltoy » Thu Mar 26, 2020 10:53 am
a nice 3 angle valve job... and back cut intake valve......
more to come... :D
Rogue-AE95
Postby Rogue-AE95 » Fri Mar 27, 2020 5:47 pm
I didn't realize those Molnar 40-20 rods required modifying the block. I had bought a set years ago from Orion, but I never used them.
Postby oldeskewltoy » Thu Apr 02, 2020 7:46 am
Rogue-AE95 wrote:I didn't realize those Molnar 40-20 rods required modifying the block. I had bought a set years ago from Orion, but I never used them.
Not always... Loynings made clearance before.... as that is easier then finding out during assembly
fresh hone....
and with the Cometic gasket fitted... NOTE: the front, and rear placement for the oil feed(front), and oil drain (rear)
and with the head fitted
more to come.... :D
Postby oldeskewltoy » Fri Apr 03, 2020 3:10 pm
A step further....
Doing a bit of custom fitting... the stock lower timing cover will not accommodate the T3 pulley snout (its broader - more diameter than stock), so the lower timing cover is "adjusted" so it will accommodate the T3 pulley
Once that detail is taken care of, the rest of assembly goes smoothly
allencr
Postby allencr » Sun May 17, 2020 12:39 am
Big chamfer, still need a ring compressor? ;)
Thanks, beautiful pics.
allencr
Postby allencr » Sun May 17, 2020 12:40 am
Thanks, beautiful work & pics.
