oldeskewltoy wrote:Sorry this is my first appearance... I typically avoid ITB threads... they aren't often needed(my 140+ whp smallport runs just fine on a single T/B), and if not done correctly can and often does cause operational issues do to poor set-up (mechanical, as well as from a management POV)yabaiani wrote:
I am absolutely doing the headwork right now too, no worries.
would love to see your work.......yabaiani wrote:
Let me go ahead and update everyone on the parts and build on what I decided to do. I am:
* Rebuilding motor with higher compression, new forged pistons, rods, valve springs, retainers, etc
* new Tomei Poncams
* Toda cam gears
* Toda timing belt
* MRP ITB Kit w/ new injectors, fuel pressure regulator, vacuum block, etc (https://www.mrpltd.co.nz/product/mrp-4a ... le-bodies/)
* Fujitsubo super EX headers
* Fujitsubo legalis-R exhaust
* standalone ECU and new wiring harness
What springs? Why retainers if you are running such mild cams?yabaiani wrote:random note...does anyone know of a good set of pistons and rods (not from MRP)? My machine shop said they would look, and I look at CP and only found pistons, not rods. Went to Brian Crower and found Rods. Don’t know if anyone makes both.
Arias just makes pistons...
Molnar Rods... they run about $450 per set... They have 2 different rods depending on which crank you have....
As to pistons, plenty of places make them... not many that you can trust - if you are going to spend $$ on forged pistons - get the right ones! But for your build level(cam choice) you don't need fancy pistons......
I probably put more things for generic engine rebuild stuff on things that I decided to not go with. Do you have any recommendations? Here is my compiled list so far...
Pistons:
- 4AG Red Top High Compression Pistons, 10.3:1 : $530NZD -> $342 USD
- Brian Crower 12.0:1 Pistors (CP7653 or CP7659) - $560 USD
https://briancrower.com/makes/toyota/4age_pistons.shtml - CP Carillo SC7653 Pistons, 12.0:1 : $680 USD
https://cp-carrillo-catalog.cld.bz/CP-C ... 96/#zoom=z - Arias 11.5:1 Pistons (3731220) - $569 USD
https://cp-carrillo-catalog.cld.bz/CP-C ... /10#zoom=z - Arias 12.0:1 Pistons (3731320) - $569 USD
https://cp-carrillo-catalog.cld.bz/CP-C ... /10#zoom=z - Wiseco K506M815 10.2:1 - 11.0:1 - $591
https://issuu.com/racewinningbrands/doc ... ODIwMTAwNQ
Valve Springs
- Toda Springs - $270NZD - $174 USD (maybe cheaper)
https://www.toda-racing.co.jp/en/produc ... g4v-5.html - HKS Springs (2201-RT004) - $148
https://shop.battlegarage-rs.com/produc ... ve-springs
https://www.hks-power.co.jp/en/product_ ... roduct/218
Not compatible with 5 valve. Lift design 8.1mm.
Cams:
- Tomei 264 IN/EX Camshaft, 7.9mm lift (stock lifters) - $500-550 USD
http://www.tomei-p.co.jp/catalogue/cam_4ag/ - Toda Racing (maybe 272) camshaft, 7.9mm lift (stock lifters) - $500-550 USD
https://www.toda-racing.co.jp/en/produc ... g4v-1.html - Kelford 193B Cams - 284/278 duration. 9.20mm/8.50mm lift. - $920NZD -> $593 USD
https://www.kelfordcams.com/nz/193-b-camshaft-set.html
- MRP 4AGE Billet H-Beam Conrods - $600NZD -> $387 USD
https://www.mrpltd.co.nz/product/4age-b ... m-conrods/ - Molnar Rods (TH4803ACB4-A) - $436.12 USD
https://www.molnartechnologies.com/sport-compact-rods/ - Brian Crower ProH2K w/ARP2000 Fasteners - $487.49 USD
https://store.briancrower.com/collectio ... 1610001539 - Brian Crower ProH625+ Connecting Rods w/ARP Custom Age 625+ Fasteners - $763.52 USD
https://store.briancrower.com/collectio ... 1610001411
