ae86 with 4agze transplant help needed
matt_86black
i am currently putting a supercharged ae92 engine into my ae86. all is fitted but having trouble with the wiring. the 22pin ecu plug has been messed up an there are no wires in it..can any1 help me out on what wires go from my own standard 14 pin plug into the 22pin plug? also wen i turn the ignition there is only a clickin noise from a relay in the dash and at the injector rail? any help?
Re: ae86 with 4agze transplant help needed
the ecus are labeled internally. if you remove the top from both ecus (dont mix up the parts tho) all the terminals have a label printed on the pcb board as to what terminal is what
