Hi, I need a stiffer springs on the front coilovers, does this fit?
http://www.ebay.com/itm/STANCE-Suspensi ... 43&vxp=mtr
									Front coilover spring
				ronny
Re: Front coilover spring
65mm is the size  - depending on what perch ur using
									Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
						BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
ronny wrote:65mm is the size - depending on what perch ur using
Should be the one from T3, so if T3 does it works? thanks!
yes that will fit the perches from the ground control kit. i.d. is 2.5 inches and so is most coilover perches
ga_goosh wrote:yes that will fit the perches from the ground control kit. i.d. is 2.5 inches and so is most coilover perches
do you think they are the same length? thanks!
yei am running 8 inch springs on my coilovers you shouldnt have any issues with those springs
ga_goosh wrote:yei am running 8 inch springs on my coilovers you shouldnt have any issues with those springs
ok thanks a lot!
