AE86 GTS Brake Rotors and Pads
Hi, I wanna replace the front and rear brake rotors,pads and lines on my 86 GTS. Want some good at both track and street but most for street tho. Looking to get slotted rotors and stainless lines. Dont really know what to go for, what brands? Any options?
Re: AE86 GTS Brake Rotors and Pads
For ss brake line don't cheap out use goodridge as brakelines
Check out the shop sections there's a few shops that have what your looking for
GL
GL
mad_86 wrote:For ss brake line don't cheap out use goodridge as brakelines
GL
Goodridge are around $150 a set, is that a fair price? seem expensive to me just few lines.
On the shop section i only found the 88rotors, i heard its not a good thing to go for.
check tirerack, i know they had them for like 115-120. get some super blue or motul to finish the install.
im going to be running some Hawk HPS pads this summer, ss lines, n im not sure what rotors. gotta replace my booster first
Jacare wrote:check tirerack, i know they had them for like 115-120. get some super blue or motul to finish the install.
Hawk HPS pads good for all seasons? I really need some rotors options, anyone?
What about this slotted rotors? http://brakeperformance.com/brake-rotor ... Rotors.php
88 rotors has good stuff. good deals on slotted rotors and hawk pads.
MisterJerk wrote:88 rotors has good stuff. good deals on slotted rotors and hawk pads.
Are they works good? ppl say don't take 88rotors but I never try tho!
I have had their rotors a couple times. they work well and last a while.
MisterJerk wrote:I have had their rotors a couple times. they work well and last a while.
which set up you used?
Goodridge are a good quality made brake line
just like anything else theres always better/ higher quality lines
But for more $$$, defiantly compare prices before purchase
As for your brake & rotor needs you gotta find
What you need , ex.rotors Slotted ,drilled , vent &non-vented,
Nickel plated, non-nickel plated you should research there's
So many choices,
Hope it helps a bit, lol
So many choices,
