So I need to figure out what c/r to run on my project. According to weisco I can do a max dome of 3.2 for the crown for the 20v pistons. Depending on the HG I use I can run a 11:1 - 12:1 c/r if my calculations are correct. How do we feel about a 12:1 c/r will the stock bt ECU freak out? Do you think it will cause detonation being only 91 octane fuel is easily available to me?
Thanks in advanced
C/R for 20bt 7age
Re: C/R for 20bt 7age
anyone?
awesome, how much shipped to vancouver?
Orange Rocket
You should try it.
you also have to tell us what kind of component you are going to use.
seems like 12:1 with 91 octane won't work unless retard the timing a lot.
Why you need to have such a hi c/r?
Are you going to use big duration cam?
12:1 is like for over 300 degree cam set up which expect to rev up to 10000 rpm or even more.
7Age doesn't take the rev so hi unless you have custom forged crank and rods.
I would say,8500 is the most you can rev since there are no race bearing for 7A crank and rods.
Toyota OEM bearing takes up to 8500 rpm usually.
there are no reason to have over 300 degree cams which needs 12:1 C/R.
So, your Ideal cams will be 272 to 288 range.
Now kind of get the answer. no?
Duy- wrote:awesome, how much shipped to vancouver?
wth......
You should try it.
Well 91 ia all I can get here unless I use race gas
more pooowwar! My 7a has all that fun custom stuff already. crank, rods ect.
ACL bearings work for one of the Honda's if I recall correctly. I am starting to think I will e more in the 11.5:1 area anyways hopefully I wont have detonation issues.
But why not?
But why not?
v33sonata wrote:You should try it.
But why not?
Hello,
Better post this in the right section
still waiting on a shipping quote, worst seller... evar
onnaj wrote:v33sonata wrote:You should try it.
But why not?
Hello,
Better post this in the right sectionThis is the sale part of the forum.
Thank you!! I'm not sure how I ended up posting here!
mods plz delete this thread
