212mm Clutch and Flywheel on a C52
- gotzoom?
Re: 212mm Clutch and Flywheel on a C52
The outer diameter of the flywheel and starter teeth are no different between the 200mm and 212mm flywheels. Only the diameter of the part that the clutch disk touches is different. A 212 flywheel and pressure plate fits under the T50 bellhousing, so I would expect it would fit under a C52 as well.
On the 4AGE they started using the 212mm FW around 86. On an AE92 if you have a 4AGE you should have a 212mm FW.
If you have a 4afe or 7afe or something else then I am not so sure about the FW size but both those motors use 6 bolt FW vs the 4AGEs 8 which means the 4AG FW wouldn't work.
apsogosGTi
yoshimitsuspeed wrote:On the 4AGE they started using the 212mm FW around 86. On an AE92 if you have a 4AGE you should have a 212mm FW.
yes it is 212mm this week i will send my 16v clutch disc and plate with the 20v flywheel for balancing
I can confirm this. I run a 4AGE Blacktop with a Silvertop flywheel and a Blacktop clutch disc and pressure plate on my stock C52 (7AFE Celica) gearbox
this isnt intirely true. the large port 88-89 ae92 actually had a 200mm flywheel the small ports had the 212mm fw or at least the 88 ae92 gts motor i pulled from a matching number car had a 200mm fw
ga_goosh wrote:yoshimitsuspeed wrote:On the 4AGE they started using the 212mm FW around 86. On an AE92 if you have a 4AGE you should have a 212mm FW.
Thanks for the info. I thought they all jumped to the 212 around the same time.
apsogosGTi
neither that is true!my bigport ae92 corolla hatch 1988 has 212mm flywheel
apsogosGTi
i want to ask for balancing my 16v pressure plate ,my 16v clutch disc and the 20v flywheel what equipment the shop should have? I asked a engine rebuild shop here and they told my for balancing all these i must bring them the crankshaft...hahahaha .Unbelievable....
look here a few balancing photos
apsogosGTi wrote:neither that is true!my bigport ae92 corolla hatch 1988 has 212mm flywheel
yours is also edm 10.1 high comp correct? the one i refering to is the usdm version
apsogosGTi
ga_goosh wrote:apsogosGTi wrote:neither that is true!my bigport ae92 corolla hatch 1988 has 212mm flywheel
yes my friend thats exactly is mine
apsogosGTi
i want to apologize about the wrong information i gave some days ago.The pressure plate of my 16v and the clutch disc that was finally 200mm does not fit the 20v flywheel.So i bought a new 20v clutch set for fitting..Tommorow i will send the presure plate and the flywheel for balancing.
Hey everyone I am new to this club. I was wandering if there a repair manual specifically for the 89 corolla gts/ ae92? Just to clarify I am assuming my car is a large port with 7 rib or is it a small port. I am planning to rebuild it.
apsogosGTi
Bakihanm2 wrote:Hey everyone I am new to this club. I was wandering if there a repair manual specifically for the 89 corolla gts/ ae92? Just to clarify I am assuming my car is a large port with 7 rib or is it a small port. I am planning to rebuild it.
The repair manual is the same with ae86 in the most of cases , you can download it http://www.aeu86.org/index/technical-ae86-manuals/cat/9/topic=5158
