4AGZE CAS rebuild kit
- speedmaster
Is there any DIY way of rebuilding the CAS instead of getting the kit?
- Attachments
- Picture for reference
- DistRebuild8.jpg (65.79 KiB) Viewed 5544 times
Visit my FB fan page at https://www.facebook.com/speedmasteracing
Re: 4AGZE CAS rebuild kit
All the parts should be available from industrial bearing and seal suppliers.
You just need to give them the details... maybe take the CAS in with you so
the sshop can measure the O-ring grooves to make sure you get the correct
size. The O-rings become distorted after a few thousand heat cycles
- speedmaster
jondee86 wrote:All the parts should be available from industrial bearing and seal suppliers.
size. The O-rings become distorted after a few thousand heat cycles![]()
I have a problem looking for a small black seal.
Sent from my HM NOTE 1LTE using Tapatalk
Nothing unusual about a 10 x 20 x 5 shaft seal. Tell your supplier to try harder
- speedmaster
jondee86 wrote:Nothing unusual about a 10 x 20 x 5 shaft seal. Tell your supplier to try harder![]()
I changed a few and still leaks. OK thanks jondee
