4AGZE CAS rebuild kit
speedmaster
Postby speedmaster » Fri Aug 14, 2015 3:29 am
Is there any DIY way of rebuilding the CAS instead of getting the kit?
Picture for reference
Re: 4AGZE CAS rebuild kit
Postby jondee86 » Sun Aug 16, 2015 9:39 pm
All the parts should be available from industrial bearing and seal suppliers.
You just need to give them the details... maybe take the CAS in with you so
the sshop can measure the O-ring grooves to make sure you get the correct
size. The O-rings become distorted after a few thousand heat cycles :)
speedmaster
Postby speedmaster » Sun Aug 16, 2015 9:46 pm
jondee86 wrote:All the parts should be available from industrial bearing and seal suppliers.
I have a problem looking for a small black seal.
Sent from my HM NOTE 1LTE using Tapatalk
Postby jondee86 » Sun Aug 16, 2015 10:05 pm
Nothing unusual about a 10 x 20 x 5 shaft seal. Tell your supplier to try harder :D
speedmaster
Postby speedmaster » Sun Aug 16, 2015 10:07 pm
jondee86 wrote:Nothing unusual about a 10 x 20 x 5 shaft seal. Tell your supplier to try harder :D
I changed a few and still leaks. OK thanks jondee
