in short, i bought a gts donor car that had a starting problem. it "fixed itself" so i just let it be. moved on to swap everything to the sr5 donee car but now when i finally finished. the car is having the same starting problem. Ill eventually figure this out but maybe somebody could shed some light so i can finally drive this car sooner rather than later
When i try to crank the engine all i hear inside the cabin are clicks assuming relays.
clutch switch works (doesnt do anything if i dont press the clutch in obviously)
starter works (jumped the starter to the battery and turned the car on)
tried a different starter relay still same problem
are there any specific volts required at the ignition switch?
ive looked at the wiring diagram and im thinking the problem is going to be in the ignition switch/ wiring
starter circuit
Re: starter circuit
tried posting attachments but it wouldnt let me
Re: starter circuit
Have a look at this... viewtopic.php?t=13283
Pretty sure that plug is for a ground wire that fixes to the chassis low down
and quite near the starter. You should be able to find it in one of the pics in
the post I have linked.
EDIT: Got curious about this as it seems to come up fairly regularly, so I went
and had a look at my own car (euro spec but the starter hookup looks to be near
enough the same).
So the starter solenoid wire does have a separate "extension" piece. One end
has a female spade terminal that attaches to the male spade terminal on the
solenoid. The other end has half of the black plug that you are wondering about.
The other half of the black plug is attached to the engine harness and eventually
finds its way back to the key switch.
If you complete that solenoid circuit your car should start off the key
enough the same).
Re: starter circuit
Omg im so blind lol i just turned it on. Its because i had that plug under the battery omg i feel stupid thanks so much i was pulling my hair out testing the relays fuses haha wow you made my day now to fix the high idle -.-
