Installing Recaro Modular L Seats into an AE86...
Postby jondee86 » Wed Jan 20, 2016 4:25 pm
Giving this its own thread as the information might be helpful to anyone else
contemplating this install with Recaro seats.
I picked up a pair of Recaro MODULAR L Series seats in reasonable condition
for cheap a few years ago...
They came complete with Recaro rails to suit whatever car they had originally
been fitted into. And since I had a spare set of poor condition AE rails that
were doing nothing, I decided to adapt the Recaro rails to fit my Ae86. As it
happens the rails on the Recaros are spaced 16" (406mm) apart, which is the
same spacing as the AE86 factory rails. So starting with these...
... I made these...
The process is not very difficult. First you have to remove the brackets from
the factory rails by grinding the head off the rivets and punching them out.
Drill thru the center of the spot weld with a 1/4" (6mm) bit and then twist the
bracket off. Note that spot welding makes the steel VERY hard, so best to use
a drill press and a sharp drill bit. Then you will have these...
Then with a lot of careful measuring and comparing with the factory rails (I did
one seat at a time so that I could use a factory rail as a reference) mark out
where the brackets should sit on the Recaro rails. Drill and/or drill and tap M6
for M6 x 19 cap screws. In some places I had to drill new holes in the brackets
to avoid hitting existing holes in the rails. This was the end result...
Installation is straightforward. The Recaros fit perfectly and are a little lighter
than the factory seats, judging by the feel when lifting them in and out of the
car. The only small issue I discovered, is that one of the rear seat fixing bolts
will not go into the bracket once the bracket is fixed to the rail. That one was
sorted by putting the bolt into the bracket before bolting to the rail. Here are
a few pics of the seats in place...
After completing the installation I made a few observations...
1. The seating position is very close to the factory position.
2. There is no gain in headroom when sitting in a normal driving position.
3. The seat cushion is inclined a bit more than the stock seats, and I felt that
my knees were raised a bit closer to the steering wheel. I am going to try a
different wheel with a bit more dish to see if it feels better.
4. The seats have more lateral support than the factory seats.
5. It is not really possible to increase the rearward travel of the seats without
a lot of work, as fixing bolts for the seats to the rails would not be accessible.
6. The factory seats are constructed to give a low seating position together
with a comfortable driving position. Choosing random Recaros that are designed
to work in other cars, does not mean that they will be optimised for the AE86.
I will run with the Recaros for a while and see how I like them after clocking up
a few thousand kilometres. They are the only seats that I think have the right
period "look" for a road driven AE86 :) If I decide that I don't like the Recaros
enough to keep them, I will refurbish and reinstall the factory seats.
PS: Cost of two pair of Bride RO rails shipped to NZ around US$400. Total cost
of my conversion less than ten bux plus some of my free time :D
aceforever
Re: Installing Recaro Seats into an AE86...
Postby aceforever » Wed Jan 20, 2016 7:24 pm
Looking good! :) Excited about the other installation pictures.
Re: Installing Recaro Modular L Seats into an AE86...
Postby Deuce Cam » Thu Jan 21, 2016 8:46 am
Looks great. I've always loved those seats for the same reasons. Most modern Recaro reclining seats (and other brands) just don't look right in old cars like ours.
How tall are you jondee86? Seat height has been a concern of mine so it's good to hear they're not much different than stock. Let us know how you like them after clocking some miles.
Postby jondee86 » Thu Jan 21, 2016 2:13 pm
Deuce Cam wrote:How tall are you jondee86?
Just checked... 180cm and 85kg in my socks, or 5'-11" and 13st 5lb for those
not yet using the metric system :) So not hard to see why getting headroom in
an AE86 race car is a problem for tall folK. I have seen a lot of builds where
cutting the floor is the only solution for a race seat and cage.
The interior edge trim for the sunroof sits right above the drivers head, and
reduces helmet space. Removing the sunroof make more room, but that is not
something I would do on a road car that only sees action requiring a helmet
a couple of times a year.
shagymc
Postby shagymc » Fri Jan 22, 2016 9:06 pm
Great write up! Maybe a DIY... either way, I currently am battling the headroom situation with my Euro R Accord seats with custom rails in a sunroof hatch. I want something lower but admittedly haven't given the current set up it's proper break in. Always great info from you jondee!
Postby jondee86 » Sat Jan 23, 2016 4:12 pm
Thanks for he kind words :) Seems that getting the perfect setup is not
so easy when you install seats designed for a different car. I went for a drive
yesterday, and at first the Recaros felt a little strange... different from the
worn out factory seats. But after half an hour of driving, they started to feel
better. When I installed the China made deep dish Nardi copy wheel that I got
suckered into buying last year, the wheel moved towards me a bit, and now
the wheel position feels good.
I've got the seat all the way back, but I'm going to experiment with moving
the seat forward one or two clicks, and changing the seat back angle. In the
past I have found that this helps "fine tune" the seating position to the point
where it feels just right :)
SgtRauksauff
Postby SgtRauksauff » Tue Jan 26, 2016 8:55 am
jondee86 wrote:The interior edge trim for the sunroof sits right above the drivers head, and
This is the exact reason why I looked to find a clean SR5 shell instead of a GT-S, so I didn't have to deal with the literal headache anymore. In my GT-S, with sunroof, with a corbeau race seat nearly on the floor itself, I almost brush the ceiling with my bare head.
In the new SR5 coupe, I have the same clearance, but sitting on a stock seat. So, with better bracketry and the race seat, I'll actually have some headroom!
Jondee, those seats look sharp. Do you know what they came out of? I didn't see it mentioned, but they remind me of seats I've seen in some Mazdas in the past, like a 323 GTX or similar.
Postby jondee86 » Tue Jan 26, 2016 1:23 pm
SgtRauksauff wrote:Jondee, those seats look sharp. Do you know what they came out of? I didn't
Good question, but I don't actually know what car they originally came from.
Similar seats were used in several JDM cars such as the 323 and 180SX, also
Isuzu and Mitsubishi 4WD's. But they did not have the two-piece side bolsters.
So these ones are a bit of a mystery :)
