contemplating this install with Recaro seats.
I picked up a pair of Recaro MODULAR L Series seats in reasonable condition
for cheap a few years ago...
They came complete with Recaro rails to suit whatever car they had originally
been fitted into. And since I had a spare set of poor condition AE rails that
were doing nothing, I decided to adapt the Recaro rails to fit my Ae86. As it
happens the rails on the Recaros are spaced 16" (406mm) apart, which is the
same spacing as the AE86 factory rails. So starting with these...
... I made these...
The process is not very difficult. First you have to remove the brackets from
the factory rails by grinding the head off the rivets and punching them out.
Drill thru the center of the spot weld with a 1/4" (6mm) bit and then twist the
bracket off. Note that spot welding makes the steel VERY hard, so best to use
a drill press and a sharp drill bit. Then you will have these...
Then with a lot of careful measuring and comparing with the factory rails (I did
one seat at a time so that I could use a factory rail as a reference) mark out
where the brackets should sit on the Recaro rails. Drill and/or drill and tap M6
for M6 x 19 cap screws. In some places I had to drill new holes in the brackets
to avoid hitting existing holes in the rails. This was the end result...
Installation is straightforward. The Recaros fit perfectly and are a little lighter
than the factory seats, judging by the feel when lifting them in and out of the
car. The only small issue I discovered, is that one of the rear seat fixing bolts
will not go into the bracket once the bracket is fixed to the rail. That one was
sorted by putting the bolt into the bracket before bolting to the rail. Here are
a few pics of the seats in place...
After completing the installation I made a few observations...
1. The seating position is very close to the factory position.
2. There is no gain in headroom when sitting in a normal driving position.
3. The seat cushion is inclined a bit more than the stock seats, and I felt that
my knees were raised a bit closer to the steering wheel. I am going to try a
different wheel with a bit more dish to see if it feels better.
4. The seats have more lateral support than the factory seats.
5. It is not really possible to increase the rearward travel of the seats without
a lot of work, as fixing bolts for the seats to the rails would not be accessible.
6. The factory seats are constructed to give a low seating position together
with a comfortable driving position. Choosing random Recaros that are designed
to work in other cars, does not mean that they will be optimised for the AE86.
I will run with the Recaros for a while and see how I like them after clocking up
a few thousand kilometres. They are the only seats that I think have the right
period "look" for a road driven AE86
enough to keep them, I will refurbish and reinstall the factory seats.
PS: Cost of two pair of Bride RO rails shipped to NZ around US$400. Total cost
of my conversion less than ten bux plus some of my free time
