ITG Filter - Those velocity stacks look to be at least 50mm long, so a filter
with 65mm internal height is not a good choice. You need to see if you can
work the 100mm internal height version in there. You can tip the filter in at
an angle when installing, so you don't have to have 125mm clear between
the end of the stack and the strut tower.
ITB Bore Size - If the ITB exit bore is 35mm dia that is a very good thing for
general driveability and response. It keeps the intake velocity higher for better
fuel dispersal and cylinder turbulance.
TPS Testing - Find the two pins on the TPS that output a variable resistance and
hook your multimeter up. Rotate the throttle slowly and watch the resistance. It
should increase smoothly with no steps, gaps or dropouts. Test the spare one
to check id there is a dead spot at the start of the movement before the value
starts to change. As the E6X does not use the IDL switch function, the position of
the TPS should park the slider on the beginning of the main resistance track.
As you can see here, the IDL switch is not a set of open/close contacts, but an
inactive section of the resistance track (the section with thin black lines either
side). I am wondering if the way your TPS is mounted has the wiper too far into
the inactive part when the throttle starts to move ?
MAP Load Sensing - There is nothing at all wrong with MAP load sensing. If the
MAP reading goes to atmospheric early, you can add fuel by manually adjusting the
map according to RPM. I think you would end up with something like this...
... but I have not researched it, so I can't be 100% certain how it works
For the
moment we are setting injector duration flat accross the rpm range for simplicity.
But that is not how your map will end up. Further tuning will give you something like
the above example.
Redline - It is sensible to set the redline low to begin. The excitement of getting
an engine running (especially with turbo upgrades) often leads to "enthusiastic"
driving on a base map. The result can be a melted piston, broken ring lands etc
from running way too lean. It is far better to work your way up slowly using the
WBO2 to make sure you stay between 15 and 13 AFR under load.
