Front suspension swapped out to include good condition espelir springs.
Front wheel bearings changed out
Brembo rotors
Will include brand new tanabe shocks( was going to install after fronts started to go).
Rear suspension has new agx shocks with tanabe springs with less than 2000 mi on them.
Rear slotted rotors with just over 500 mi on them.
Hawk HPS pads all around
T3 panhard bar
Unknown brand front and rear trunk strut bar.
Have inner bar that hooks up to seat belt bolting location, but removed due to getting in the way of cleaning the back seat.
Replaced spark plugs and wires with with platinum ngk's at 179k
Motul tranny fluid change about 1500 mi ago with new t3 shifter bushing kit.
Put in common hks mushroom intake (currently not installed due to just smogged)
Front Kouki bumper conversion with correctly working turn signals.
Kouki front grill not installed but will be included.
NRG quick release with brand new Nardi wheel.
LED's added to light up instrument panel better.
New HKS sport exhaust.
Solex locks
New Clutch Slave and master cylinder
Lexus Is /Celica clutch and brake pedals
The bad
Car appears to have been hit on the back driver's side. Nothing major with no frame damage, but unfinished bondo job is an eyesore.
Overall paint job needs to be done
Ac/Heat control switch needs to be replaced (have replacement but will probably need new cables)
Wheels are nothing special
Added spacers and new longer studs due to 15x8 with +20 offset wheels that came with the car.
Hood will need to be replaced since its ugly and hella heavy. Currently held down by hood pins (doesn't lock). You will need a new cable, but I have a replacement hood latch to include.
Some rust spots here and there.
No LSD
No rear view mirror (has wink mirror style)
No sun visor's
This is all I can think of right now. Like most, it pains me to let his go since I looked for one for years that was at least something I could drive on the weekends. This car drives smooth and is together enough to daily if needed.
Car just smogged on 11/11/15 and next registration will be not due until Nov 2016.
Asking $5k
