My red hatch (fix-up and restoration)
Grant
Re: My red hatch (fix-up and restoration)
Postby Grant » Sun Jan 10, 2016 7:08 pm
Thanks for the compliments. :)
The axle confusion was mainly about the tapering that people claimed was the difference between zenki and kouki axles. I measured the axles and they match up with zenki LSD axle measurements.
As for the LSD, actually it's a Cusco 1.5way LSD. The previous owner told me he put it in after the original died. I have verified it locks up very well. :lol: :lol:
At the moment I'm waiting on getting my front suspension parts back from sandblasting/powercoating. Pretty excited! 8-)
Grant
Postby Grant » Tue Mar 01, 2016 1:49 pm
Finally another update on the front suspension parts:
Got some of my parts back from sandblasting.
Again I'm using POR-15 for coating. My rear axle that I also coated with POR-15 still looks like the day I painted it, so hopefully it stays that way. :)
I had the springs powder coated because they are a pain to paint. I'm curious which coating will fail first?
Finally done with all the painting for these parts. 8-)
Now the only parts left to paint are the struts. Those are on my to-do list for next weekend.
I am choosing to leave the cross member for later since I don't have access to an engine hoist for supporting the engine (I know I could put wood under the oil pan, but I don't like that idea).
That's it for now! I'll have more updates as I start putting the car back together. :D
trigun402
Postby trigun402 » Tue Mar 01, 2016 5:45 pm
All nice and clean
notnilc20
Postby notnilc20 » Wed Mar 02, 2016 11:31 am
Loving your build cleanup restoration. great job so far. Did you measure your rear axles? From what I understand the zenki axle is 24 millimeters diameter, and the kouki axle is 25 millimeters diameter. I am currently in the never ending search for a complete rear end right now and would love to know how your rear end turned out. sounds funny. 8-)
Grant
Postby Grant » Sat Mar 05, 2016 11:10 am
notnilc20 wrote:Loving your build cleanup restoration. great job so far. Did you measure your rear axles? From what I understand the zenki axle is 24 millimeters diameter, and the kouki axle is 25 millimeters diameter. I am currently in the never ending search for a complete rear end right now and would love to know how your rear end turned out. sounds funny. 8-)
Thanks for the comments!
Yes I did measure them. Both are zenki LSD axles and with a 24mm spline diameter. Basically the main point I discovered is the tapering on the axle does not tell you if it is zenki or kouki. You must measure them. :)
Grant
Postby Grant » Wed Mar 23, 2016 7:06 pm
Another quick update. I've been pretty productive with the car since I am moving and I need to get the car driveable.
Putting everything back together, bushings are all in and greased.
I cleaned up and painted the front calipers and brackets so they match the other shiny parts. I didn't even disconnect the brake lines, it just took some clever work with the painters tape. :P
Almost time to put the wheels on! 8-) 8-)
I'll get another picture of the finished job tomorrow.
I am pretty pleased with the results after taking a quick drive. Handling feels much nicer and there isn't really a noticeable increase in noise or vibration.
Grant
Postby Grant » Sun Apr 03, 2016 1:22 pm
Here is a bit better shot of it all reassembled.
I have a question for anyone who has experience with long trips with their AE86. Do I need to worry about sustained RPMs around 3500-4000? For example highway cruising at 65mph. I am about to make a 550 mile trip with the car which is mostly highway. I know the car loves to rev, but how long is safe to sustain that kind of engine speed?
If anyone wants to share their experience with long trips let me know. ;)
Grant
Postby Grant » Sun Aug 07, 2016 3:03 pm
Well it has been a while since my last post. Moving is quite a lot of work, but I'm pretty much settled now and I wanted to give a quick update.
My car made the long trip without any problems! The only thing I had to do on the way was tighten the A/C belt a little since it was brand new and stretched during the trip.
In May of 2016 my car officially turned 30 years old (according to the metal placard on the driver side door), so I like to think it's doing pretty well for its age. ;)
At this point since the car is 100% functional, and most of the wear items have been replaced I will be focusing more on the cosmetic restoration (basically dumping money on paint and bodywork :lol:).
Grant
Postby Grant » Mon May 27, 2019 6:19 pm
Hello again, I've been off these forums for a while now, but I figured it was time to give an update again since I'm starting more work on my car, with more updates to come later this year probably.
A lot has changed since I posted last, including moving again, this time several thousand miles so I decided to not drive the car. :lol:
My latest project has been on my checklist since I got the car, replacing the old crusty exhaust. I finally decided on an HKS Hi-Power.
I had to cut the old pipe off because I couldn't jack the car up high enough, but HKS exhaust fit over the axle a lot easier and didn't require jacking it up that high.
Besides the fact that I am missing an exhaust hanger (hence the jack holding up that part) the exhaust fit perfectly as you would expect from HKS.
The catback also fit together great with a Magnaflow catalytic converter for the AE86 in case anyone wants to know.
Once I have everything bolted back together I'll post up a video comparing the old stock exhaust to the HKS, because you can never have enough exhaust comparison videos. 8-)
scalpel
Postby scalpel » Thu Jun 20, 2019 11:22 am
Always one of my fav build
Grant
Postby Grant » Tue Jul 02, 2019 11:04 am
Sorry this took forever, but I finally uploaded a clip of the exhaust comparison. The phone has some trouble picking up the lower sound of the HKS, but the improved note is obvious. I was going to record a drive-by too, but didn't get to it yet. The sound is amazing and I am glad I picked the Hi-Power over the HKS Sport exhaust.
https://www.youtube.com/watch?v=qIgOMizhdF0
I'm working on patching some rust spots and other body work now, so I'll have more updates later.
Grant
Postby Grant » Wed Oct 06, 2021 10:00 am
It's been a long time since my last update... obviously much has changed for everyone since 2019.
My car is still running strong, but this winter I decided to finally start rebuilding the spare engine I have.
I'm fairly certain it has never been rebuilt, so it's a decent starting point, and I'll be taking it down to a machine shop to have it cleaned up next week.
I also have a rebuilt head ready to go as well, and I'll share all the parts I'm using as soon as I know for sure what to order.
My goal is just to have a nice reliable engine with slight performance upgrades. I'm thinking Tomei Poncams and some better valve springs, along with better ARP bolts and studs for the top and bottom.
Grant
Postby Grant » Wed Oct 13, 2021 12:01 pm
Here are some more shots after taking everything apart and preparing it for the machine shop! I'll post pictures of new parts as I get them too.
Sepheroth86
Postby Sepheroth86 » Mon Nov 01, 2021 9:35 am
Keep it up with the posts.
It is pretty quiet here these days. I recently pulled my AE86 out for an inspection after a decade of it sitting in the barn. I am unsure if I want to start the journey on the car or simply sell it as-is..
Grant
Postby Grant » Mon Nov 01, 2021 1:29 pm
Sepheroth86 wrote:Keep it up with the posts.
It sure is quiet, but I'll keep updating this thread even if I'm the only one reading it. :lol:
It's a good way to track my own progress (or lack thereof) anyway.
Got any pictures of your car? I'm sure you know the values of our cars have been skyrocketing lately...
Sepheroth86
Postby Sepheroth86 » Tue Nov 02, 2021 10:53 am
I have a couple of pictures on my phone that I took. The car is not as nice as it was when I parked it for sure. Definitely needs some repair before it gets out of hand.
I am not sure how to post pictures on here anymore. lol
Grant
Postby Grant » Fri Mar 11, 2022 12:12 pm
Quick update on my engine rebuild. I finally received all the parts I needed!
Some other gaskets and stuff aren't in the picture, but these are all the important parts. :)
In other news I swapped my steering wheel for a JDM one. I've always thought they look way better, and it just took a long time to find one in good condition.
I'm just waiting on scheduling now and then I'll start getting the new engine back together!
Grant
Postby Grant » Wed Sep 21, 2022 6:42 pm
I have another quick update on the engine build. Basically I'm waiting on rods from Molnar rods before I can put everything back together, and I don't have an ETA for those parts yet...
Over the summer I had the bigport head cleaned and ported by oldskewltoy! (check out his thread here):
I'll get some better pictures of it when I reassemble everything, but for now it's staying safe inside that bag. :lol:
I also got some aftermarket forged hi-comp OEM-like pistons from Traum!
That's it for now...
ariel_86
Postby ariel_86 » Wed Oct 19, 2022 1:33 pm
This makes me want to update my thread with new links for pics and covering some of the things I've done (and not done) over the last few years. Keep up the good work!
1985 Toyota Corolla Sport GTS - Ariel - 105.5 whp 93.8 ft-lbs of torque
2006 Toyota Tacoma SR5 V6 6MT - mmm, taco!
2006 Mitsubishi Lancer ES 5MT - 2slow
Grant
Postby Grant » Fri Jun 28, 2024 5:17 pm
It's been another long period of waiting, but I finally got my engine back. The bottom end is all assembled, machining and balancing is all done, and it's ready to put back together. I'm first going to paint it with some "black oxide" coating to make it look more OEM.
I have some other work planned while the old engine is out before I drop the new one in though:
  • Clean up and repaint parts of the engine bay
  • Replace crusty old power steering lines with newer ones that I have
  • Remove the subframe, get it cleaned up and repainted
  • Remove the transmission and get the MFactory 5th gear installed
That shouldn't take too long, and I can start assembling the new engine in the meantime too, so I'm hoping to have it all back on the road this summer... or at least by the fall. :D
More updates/pictures to come soon now.
Grant
Postby Grant » Sat Jul 06, 2024 7:01 pm
The old engine is out! The hardest part was really just getting the input shaft detached from the engine. I can imagine it being a pain getting lined up when it's time to put the new engine in. :lol:
Now I have plenty of room in the engine bay to clean things up over the next couple months...
Grant
Postby Grant » Wed Aug 28, 2024 9:07 pm
Another rather boring update, but last weekend I pulled out my transmission.
First it needs a really good cleaning, but I will then take it off to be inspected and have my MFactory 5th gear installed!
I'm also going to swap the drive gear for my speedometer off another GT-S transmission I have because I'm sick of the speedometer reading 10mph too fast. Related video below for anyone who wants to know what I'm talking about.
https://www.youtube.com/watch?v=VfaINn2k2y0
Grant
Postby Grant » Fri Jan 10, 2025 3:31 pm
This is going to be a huge update as I have been pretty busy over the past months, but haven't had much if any time to post about my progress. I'm now nearly ready to start putting the engine back into the car! It's been a really fun process seeing it all slowly come together, and I'm really hoping that my slow and methodical approach will mean that the first start-up will be successful, and I won't find any surprises.
After pulling out my transmission, I went ahead and pulled out the cross-member too. This was a huge pain because I had to crawl under the car and loosen some of the suspension components to get it out, but it was worth it. I took it along with the transmission support and valve covers off to get powder coated, and the results came out great. 8-)
While this was being done, I also prepped and painted my engine block with some "black oxide" coating from Eastwood. To be honest it was rather hard to work with and the sprayer left a lot to be desired, but the results ended up very nice as well... after waiting a month for it to fully cure! In hindsight maybe I shouldn't have gotten paint on the freeze plugs, but it will all get dirty eventually anyway.
At this point I can finally start reassembling the engine! I have some new torque paint, and I am enjoying using it on everything. :lol:
I'm using ARP studs which I know are overkill here and bolts would do fine, but here we are anyway...
I was told the studs were actually used to increase rigidity with racing engines where the engine itself was used as a structural component.
For the head gasket I actually used the OEM gasket with the standard thickness because some material was taken off both the head and block, using something like a TRD head gasket would have made the space between the pistons and valves too small for my comfort level, and I'm not trying to push performance that much.
Test fitting the new Tomei Poncams! I was a bit confused that both the intake and exhaust sides had a gear for the distributor, but they seemed to line up correctly according to the Toyota service manual diagrams.
Now before I can continue assembling, some cleaning and repainting needs to be done, which I find to be some of the most time consuming work. I tend to put it off, so I decided to get it all over with at once.
Moving onto degreeing the cams here, which I've never done before, so it was very good to learn the process and practice it many times until I felt comfortable that things were set correctly.
Shout out to CM Autohaus/Ezekiel for this great summary video on the process for our engines: https://www.youtube.com/watch?v=XuX2caLj_zY
Test fitting my freshly painted timing belt covers, and making sure I remember how the engine mount brackets go back together.
Other than that, I have decided against installing my MFactory 5th gear this time around because I want to get the engine back in first before I tackle a huge rebuild process with the transmission. I did however replace all the seals and gaskets within my current transmission, and have it ready to go back into the car as well.
Well... I think that's all my updates for today. Next time I hope to share some news on first start-up of my engine and start driving my car again. It's been so long I almost bought another old Toyota to scratch the driving itch while I get mine back together. :lol:
Something about these cars that newer ones just can't seem to replicate.
Until next time!
Jayrdee
Postby Jayrdee » Mon Jan 13, 2025 12:27 pm
How much (if any) did you have to adjust your cams to get them set? The picture looks like your cam gears are still set at 0?
The reason I ask is because this is something I did not do :lol:
I installed my cams at 0 degrees at TDC using the timing marks on the oil pump and the back timing plate, then verified valve lash. I'm now wondering if I need to stop being stingy, buy myself the tools, and go back to degree my cams Lol.
_____________________
instagram: @dacobjurbin
Grant
Postby Grant » Tue Jan 14, 2025 1:34 pm
Yea, that picture was probably taken before I finished, silly of me.
I probably did it 10+ times because I didn't trust I had my dial gauge stable enough, and in the end the adjustment was close to zero, but not exactly. I'll take a picture later today of where I landed, but of course every engine will be slightly different.
For a mild build it's probably not necessary, but it was fun to learn anyway, and who knows maybe it will give me an extra 1HP in some cases. :lol:
Grant
Postby Grant » Tue Jan 14, 2025 3:42 pm
Okay here is where I left the gears, you can see they are almost at zero, but not quite. This adjustment kept the openings and closings of the intake/exhaust values lined up exactly with the cam card, otherwise I think they were happening 10-20 degrees before/after they were supposed to. It is interesting that a very small adjustment of the cam gears causes a proportionally larger difference in the degrees of when the open/close/max-lift events happen.
Jayrdee
Postby Jayrdee » Wed Jan 15, 2025 7:15 pm
Gottcchaaaa... Very good to know!
I think I might be okay since my cams aren't as aggressive as your poncams from a degree standpoint. I had Dan (oldskewltoy) source me some Cat 244 / 8mm lift cams.
What compression ratio pistons did you get? I'd be very curious to see what kind of numbers you will get out of your motor compared to mine since they will be somewhat similar.
Postby oldeskewltoy » Sat Jan 18, 2025 3:06 pm
Jayrdee wrote:Gottcchaaaa... Very good to know!
It never hurts to check, the Cat 244 cams have centerlines of 110 if I remember correctly. The pistons Grant is running are forged versions of the smallport piston, stronger, a bit lighter.
Grant
Postby Grant » Wed Jan 22, 2025 3:20 pm
Thanks for chiming in Dan.
The compression ratio is for the small port high comp piston is 10.3:1, so with some material taken off the head/block (I don't have exact numbers on those in front of me), and a stock head gasket at 1.2mm thickness (torqued), that would put me very slightly above 10.3:1 (it makes sense to me anyway).
The plan is still to run this all on the stock ECU for now, so I didn't want to push my luck there.
I am planning to dyno the car at some point after it's back together because I'm curious about the numbers too.
Grant
Postby Grant » Fri Mar 21, 2025 4:11 pm
Well it's taken forever to find the time to post this update, but the big news it that I finally have my car running again! :D :D
Before installing the engine I had to reinstall the transmission and replace some of the shifting components... the throw out hub was very worn along with the shirt fork itself.
Two more videos from CM Autohaus that really helped make sure I did the install correctly can be found here:
https://www.youtube.com/watch?v=CRLIWmnToZA
https://www.youtube.com/watch?v=wTduDCK6m_k
I did run into a slight annoyance with installing the engine with a power steering rack. There is a bolt for the fluid line that collides with the rear cover plate on the engine. The trick to get over this is to tilt the rear of the engine up until the plate is just touching that bolt, then by hand just carefully lift the plate over the bolt towards the transmission. Then you can tilt the engine back in line with the bell housing and continue getting it aligned with the input shaft.
Another engine install tip... don't hook the engine up like it is below, where the chain does not have enough swing/slack. You need to be able to push the engine backward into the transmission. I had to pull the engine out and use more chain after I took this picture.
I originally hooked it up this way because I thought I didn't have enough clearance above for the engine crane.
After a lot of adjusting and shaking of the engine, it finally slid into the input shaft and the install was successful!
Fast forward another couple days and I have most of the accessories re-installed.
At this point I thought it was about time to start up the engine for the first time, but of course I hit another problem... leaks after filling up the coolant for the first time. There was a leak at the coolant hard line mating surface, and even a small drip from the weep hole of my new OEM water pump! :cry:
(the weep hole leak did stop after the engine started up, go figure... :roll: )
I decided to fix the coolant line first, and just hope the weep hole drip fixed itself after start-up... the coolant line from Flo's wasn't exactly the same, but I made it work. I think the mating surface on the old line was too rough for the gasket to seal properly... but I kept it just in case I try using it again.
In hindsight, maybe it's worth filling the engine with water when it's on the stand, plugging the outlets, and test for leaks that way first? It was a pain having to take all the intake parts out twice.
After all this was replaced, and I refilled the coolant, I was ready to start the car up!
Very important tip here, I discovered my distributor was a single notch off and it was stopping my engine from starting up. Here is the comparison of where the rotor should and shouldn't be at cylinder #1 TDC.
Note that this is for my specific engine build, and yours might require different timing, but a single tooth off will stop your car from running.
Once I fixed my ignition timing, I let the car warm up, bled the coolant, confirmed no leaks, and started the engine break-in process.
I was having trouble keeping the car idling without stalling, so I had to open the idle screw on the throttle body all the way at first. I think there might not have been enough coolant in the IACV which was messing with the idle. Later I was able to tighten the screw back down and get it idling around ~900-1000 RPM. The idle is lumpy because of the Poncams I have installed, but otherwise it sounded great! 8-)
Here is a short clip of it idling, I've never had oil pressure so high at idle before... :lol:
https://www.youtube.com/watch?v=qny_Gk0Xkvk
For break-in I was doing wide-open-throttle pulls from 2000-4000 RPM, and then 2000-5000 RPM in second or third gear, and letting the engine break with the throttle closed back down to 2000 RPM and repeating. I repeated this process for a few hours split over a couple days, I think about 30 miles or so of driving.
After that I changed the oil and filter, this was probably overkill and changing just the filter might have been fine, but I wanted to get as much metal from break-in out as possible.
The oil I'm using is Driven BR40.
Now the plan is to drive another 500 miles or so, and do one more oil change with non-break-in oil. I'm not sure whether to go with synthetic or conventional, does anyone have opinions on that?
