Hey guys,
My 16v has been feeling a little weird at low speeds. If I'm in 1-3 gear and remove my foot from the throttle, the engine starts to rubble and shake. This is even happening in 3rd if I'm anywhere below 2800rpm. Giving it a little gas helps a bit, but it isn't until I'm giving it a significant amount that it goes away. Right now, to make a slower turn in 2nd or 3rd, I have to clutch in to avoid the bogging.
4th gear, I have no issues at all with taking my foot off of the accelerator. When I do, things still feel very very smooth.
Any ideas? This has made any low speed driving, such as through my neighborhood, a huge pain.
Thanks!
16v not feeling too great at low speeds.
Re: 16v not feeling too great at low speeds.
might there be something wrong in the transmission? I know it isn't the engine, but when you say it is in gears 1-3, but once in 4th all is fine. When the trans is in 4th gear the power goes straight through the trans where in 1-3 it goes into other shafts, gears.
oldeskewltoy wrote:might there be something wrong in the transmission? I know it isn't the engine, but when you say it is in gears 1-3, but once in 4th all is fine. When the trans is in 4th gear the power goes straight through the trans where in 1-3 it goes into other shafts, gears.
Hmm I didn't think about that. My transmission shifts fine and doesn't seem to give me problems (unless this is a transmission issue). Having my foot off of the throttle in 5th gear is fine too.
If it's the trans you'd more than likely hear a new noise or feel something odd. How does the engine do when revved in neutral?
One shot, one kill.
What's the compression?
Does it miss or surge or feel funny when redlining 2nd & 3rd?
Is the timing adjusted for a smooth fast idle, and octane so it'll only ping/detonate if abused, like trying to accelerate in 3'rd at 2000rpm?
Diagnostic check ? If it is not the transmission then it could be a fueling issue and possibly also related to the TPS (fuel cut, or lack of, on the idle switch)
