Throwout bearing problems
racer555
Postby racer555 » Wed May 11, 2016 3:04 pm
I have had a noisey throwout bearing since I bought my corolla. Its a 1985 sr5 converted to gts still with an sr5 bellhousing. I got the spec clutch stage 1 kit for a gts since I was under the impression that it should work. The clutch disc and pressure plate are fine but the throwout bearing is different. I haven't been able to get a response from spec about this and was wondering if the throwout bearings are different from a gts and a sr5?
morgan
Re: Throwout bearing problems
Postby morgan » Thu May 12, 2016 4:38 am
the bearings are the same between gts & sr5, ive heard of many companies supplying the fwd bearing with rwd kits. possibly, the bearing is on backwards if its the correct one?
My turd of an 86
20v swapped 86 write-up
racer555
Postby racer555 » Thu May 12, 2016 11:02 am
I emailed a picture of the bearings side by side to spec clutch. Just waiting for a response.
ae86714
Postby ae86714 » Fri May 13, 2016 2:31 pm
Pretty common issue
viewtopic.php?f=9&t=9690
Exedy PN: BRG201 is the right TOB
