I'm in the process of my first sr5/gts conversion. I was able to find a gts parts car with no motor, and then later found a bluetop 16v. All wiring harnesses are from a zenki. I have most things sorted out except for a few plugs and wires here and there. I've checked the electrical wiring routing diagrams but I'm not 100%.
image upload1= Test connector?
2= Electrical idle-up VSV ?
hosting images3= ??
4= A/C compressor sensor?
5= A/C magnet clutch ?
print screen windows6= Cruise control actuator
post imageThese two (red and black) come from the starter. Just wondering where to connect them.
screenshot toolWhich bvsv do I use to reinstall my charcoal canister? the previous engine owner removed the egr and canister.
gif hostingIs this a fuel return line? Does it just connect to one of the hardlines that go to the tank?
image hosting gifDoes this ground connect straight to the alternator.
Thanks for the help.
