Anyone care to critique this hone job? Kinda new to this and wanted to take a crack at it. Using an electic hand drill with 800 max rpm, about 1 up and down stroke per second (pretty much as fast as i could move it) using generous amount of 10w30 conventional oil as lube per FlexHone recommendation, for about 5-8 seconds per cylinder, with a 240 grit FlexHone bead style bottle brush hone thing, whatever you wanna call it.
Side by side with honed and un honed cylinders
After finishing I washed out the cylinders with liberal amounts of hot soapy water multiple times, gave it a good rinse, wiped the block dry, then 4-5 passes with clean oiled up rags until the rags came out looking the same way they went in, clean. Then a final light coat of WD40 to prevent any surface rust.
How's it look to you?
