Short stroke strut service
Re: Short stroke strut service
Thinking of doing this but was wondering if there are any issues of keeping the coil over sleeve from spinning while trying to turn the height adjuster plate? Thanks.
notnilc20 wrote:Thinking of doing this but was wondering if there are any issues of keeping the coil over sleeve from spinning while trying to turn the height adjuster plate? Thanks.
If you run o-rings over the strut casing in between the sleeve and the casing that will usually keep it from spinning. Also a customer in the past had the same concern, so I added a tab on the perch that fit into a slit I milled into the sleeve to keep it from rotating.
breezefabrication.com
ryan@breezefabrication.com
AE82 guys don't feel left out.
Burning Rod
This is awesome!!
Mister S
1986 Toyota Corolla GT-S
2018 Ford Focus RS
2019 Ford Fiesta ST
2018 Ford Focus RS
2019 Ford Fiesta ST
