toda 264 10.3 lift vs hks 288/272 10.lift
killercam
Postby killercam » Fri Jan 05, 2018 8:09 am
need help with my set up cant decide which ones to go with for a street car im running old school hks supercharger
can anybody give me advice on this set up pistons 10.5.1 20v block aftermarket rods also.
toda or hks all valve train has been upgraded,
Re: toda 264 10.3 lift vs hks 288/272 10.lift
Postby oldeskewltoy » Fri Jan 05, 2018 10:53 am
What management?
What static compression ratio? Whoops 10.5:1
HKS supercharger similar to SC12, so it won't benefit from an engine that spins over 8000 rpm.... I'd stick with the Toda 264 cams. Just make sure you don't have an interference issue with either cam - they both are tall enough that the head may need to be worked to get the cams to actually rotate
killercam
Postby killercam » Fri Jan 05, 2018 10:59 am
thank you for the info, also will be aem ecu.
Davegt27
Postby Davegt27 » Fri Jan 05, 2018 4:23 pm
the post is deleted
Davegt27 Code One Racing
Users browsing this forum: MSN [Bot] and 3 guests
