Blacktop shutsdown while pressing clucth
Mehmaddict
Postby Mehmaddict » Mon Mar 26, 2018 10:01 am
Hi everyone. I have 86 swapped Blacktop 20V running with Vems Ecu.
When you rev on first gear, engine shutsdown while pressing clucth.
If you drive normally no problem.
Plus interesting thing is when you rev the engine and stop the car, Starter motor doesnt work. But starts perfectly when cold.I dont know maybe its connected.
Thanks everyone.
Never Gets Old //
Davegt27
Re: Blacktop shutsdown while pressing clucth
Postby Davegt27 » Thu Mar 29, 2018 9:53 pm
I don't have an AE86 but it sounds like your clutch inter lock switch is either faulty or wired backwards
so in other words you can start your car without touching the clutch pedal but as soon as you push in the clutch the car dies ??
Davegt27 Code One Racing
Mehmaddict
Postby Mehmaddict » Tue Apr 10, 2018 12:09 am
Thanks everyone , It's all about ISCV issue. Removed, solved. made custom part for it.
Never Gets Old //
