DIY: LED Bulbs and Fixing Hyper Flash Turn signals
cincybranr
Postby cincybranr » Thu May 17, 2018 7:30 pm
Hey all,
Probably a topic that hasn’t been brought up in awhile, LED bulbs. I came across something I wanted to pass on and I take Zero Credit for it!
Problem: I installed LED Turn signal bulbs and now they Hyper flash! What do I do?
Solution: After searching with no luck for an off the shelf Turn signal relay that was Plug-n-play, I came across a free, easy fix that may help you as well. See link below. EDITED 4/23/20..Link not working so picture posted.
Image8B22FD75-6FC1-4500-9936-0793340207F8 by Brandon, on Flickr
https://www.celicasuprawiki.com/index.p ... ED_Flasher
Some background info below regarding LED bulbs on my car.
My Car:
1985 AE86 GTS (Zenki) with Toyota 'Green' Turn Signal Relay Part # 81980-22070
Sylvania ZEVO LED's for all outside bulbs (Color Specific)
I read all sorts of horror stories about polarity issues, connection issues, Hyper flashing etc, but I read great things about the new LED bulbs and decided to give a Sears Gift card from christmas a go. I also thought LED lights would look awesome behind my new Sprinter tails.
I had Zero issues after installing Sylvania ZEVO LED's. Everything fit perfect, lit up great, and brake lights worked perfect as well. I went with their color specific bulbs (Amber for signals, Red for running lights/brake etc).
Hopefully this inspires some confidence out there..
Progress. Not perfection.
Re: DIY: LED Bulbs and Fixing Hyper Flash Turn signals
Postby jondee86 » Fri May 18, 2018 2:21 pm
Good information. How do the tails look with red LED's behind the red lens?
Are they brighter or darker than with standard bulbs?
cincybranr
Postby cincybranr » Fri May 25, 2018 7:16 am
jondee86 wrote:Good information. How do the tails look with red LED's behind the red lens?
Pretty bright actually. I wish I would have done a before and after. Sylvania recommends color specific LED bulbs behind colored lenses. I was skeptical at first but the prices were the same so i thought I would try it.
New Pictures coming soon... (Edited 4/23/20)
