Keep the bigport? 7age build
I want to build a 7age, but have been given advice to dump my bigport head for another option. Is all lost with the bigport?
Re: Keep the bigport? 7age build
I guess it depends on who gave you the advice and if indeed you would take any advice offered here ?
No. Only thing lost, is the one who gave u that advice.
From normally aspirated street to 500+hp, bigport been there done it
what is your goal ?
I'm looking at around 160+, and I want to stay NA.
search the crapload of 7AGE builds on the net. More than a few raved about their bigport 7A builds
I'd imagine you're after the torque increase.
Its CRITICAL u get cam timing in sync. Some fail = disappointing performance
I'd keep TVIS & intake (unless u got ITB plans).
Look into smallport pistons/final 7A comp ratio (compatible with your fuel)
carefully choose proven cams..... probably 7500rpm redline
tune with most basic megasquirt
A lot depends on the induction system, I would think the TVIS bigport inlet would struggle a bit with cams, a longer stroke and 160hp
The smallport inlet would cope better and you could get away with shorter duration cams.
I've got an aftermarket ecu running slivertop itbs. I had thought about smallport pistons. On cams, I was thinking of 272 both, or catcams 275/267 setup.
for a daily driver tvis could only enhance 7age torque.
Yeah, 160hp require fairly aggresive cams, that might leave the intake behind ? dunno
Vehicle use & hp goals would dictate intake - broad midrange tq, or peak hp
if screaming around with noisy ITBs, where the tach rearly see under 5000rpm = different scenario
160hp crank or wheel?
google 2sec; http://www.speed-industries.ch/wordpres ... e/?lang=en
like i said, really no need to guess at any of this. Too many examples out there
First... the is no reason for you to ditch the largeport head, as you will be using ITBs.  If you were retaining the stock manifold, it might be worthwhile to run a smallport to achieve your power goals
160hp... or 160whp? - - VERY important difference
ASSUMING the later..... 160whp
To run those cams(Cat cams listed) the head will perform a WHOLE lot better with port work, the 275 is 10mm of lift, so you MAY need to have the lifter buckets machined for the cam to physically turn.
As to the pistons... You could run either stock 4AGE piston, but why? You are building a performance engine, and unless you have something to prove, I'd look to get a better designed piston (with holes for the oil rings to evacuate oil instead of a slit).
2 things are VERY important with a 7AGE..... 1) as has been mentioned, cam timing. You can purchase a "broached" (re-cut) crankshaft timing pulley, or not - but it is always best to set cam timing AFTER you have confirmed TDC. 2) Set piston squish @ .032" (+ or - .002") - "Squish" is the gap between the top edge of the piston @ TDC, and the flat parts of the combustion chamber.
The crankshaft can likely survive 8500 rpm, the stock rods may.... or may not, I'd recommend MRP 7AGE rods.
If I were building your engine, I'd recommend big valves(32mm intake, 27.5mm exhaust), and instead of the Catcams 275/267, I'd recommend a set of the big lift(10.7mm) 268 cams. I'd run a custom piston, the crown would be -2cc volume, and MRP rods.
Max2503 wrote:I've got an aftermarket ecu running slivertop itbs. I had thought about smallport pistons. On cams, I was thinking of 272 both, or catcams 275/267 setup.
OST Cyl head porting,  -    viewtopic.php?f=22&t=300
I like your recommendations for the build...any idea on suppliers for the cams and pistons?
Also, with this build, will I notice an improvement over a 4age with the same mods?
Max2503 wrote:I like your recommendations for the build...any idea on suppliers for the cams and pistons?
I can get you the cams... the 268/10.7mm cams WILL REQUIRE machining the lifter buckets to rotate. The pistons should not be too big a deal.
If both engines have the same cams/compression, and the build quality is equal the 7AGE will make more power than a 4AGE.
So, what was the outcome on this? I can tell you a 7AGE is a fantastic daily driver machine. I did a budget build on one of these and the guy that has it loves it! It was a mild build for sure, stock valves with mild port work and a WEB Cams 294 grind set of cams. Used USDM low comp pistons on the stock 7A rods, compression ended up at 10.3 to 1. Makes a stock 4AGE look like a slug, especially off the line. One of these days I'll get mine built.
									One shot, one kill.
