Hello
To install 20V BT OEM flywheel into an AE86, all I need is the clutch pressure plate and disc from an AE92 GTS, correct?
Thanks
20V BT OEM flywheel question
Re: 20V BT OEM flywheel question
Correct. Should be 210-212mm outside diameter clutch disc. Use the
AE86 throwout bearing and spigot bearing (if you have a 20V engine).
^^^ thanks Jondee86
