Header and down pipe gasket
hi, does anyone know where to buy gaskets for the ae86 16v header and down pipe gasket? just got the aftermarket header so I might need a set of new gasket. I'm in SoCal. Thanks!
Re: Header and down pipe gasket
Check eBay or rockauto, they should have the gaskets.
jojor42 wrote:Check eBay or rockauto, they should have the gaskets.
Its 2.5"right?
OBX sells a kit on ebay for this, its $15
http://www.ebay.com/itm/181080185275?ss ... 1423.l2649
My turd of an 86
20v swapped 86 write-up
My turd of an 86
any of the chain auto parts stores carry 2 bolt exhaust gaskets. you just have to know the size of the piping. stock cat is 2"
OBX has a 2" outlet
Pacesetter is 2.25
which aftermarket header? not all are the same size. and i havent seen very many 2.5" exhausts for the ae86, other than the CXracing one.
OBX has a 2" outlet
Pacesetter is 2.25
morgan wrote:OBX sells a kit on ebay for this, its $15
isn't it only for 20v?
RLZ wrote:isn't it only for 20v?
nope the ends are slotted for both 16 and 20
manifold gaskets are cheap and arent anything special, felpro works.
MisterJerk wrote:any of the chain auto parts stores carry 2 bolt exhaust gaskets. you just have to know the size of the piping. stock cat is 2"
OBX has a 2" outlet
Pacesetter is 2.25
I don't know what brand of the header, but looks like pacesetter 4-2-1.
RLZ wrote:morgan wrote:OBX sells a kit on ebay for this, its $15
nope, you can see the slots for 16v & 20v applications. i have bought this kit before, the gasket for the header/downpipe flange is 2.5" I.D.
pacesetter doesnt utilize that gasket since its a shitty slip joint
My turd of an 86
My turd of an 86
pacesetter doesnt utilize that gasket since its a shitty slip joint[/quote]
So do you know the size will fit pacesetter header?
the one in the kit will fit the header where it meets the catalytic converter. its only a little bigger for the opening, i dont think it will hurt none. youll be fine with that kit, i like the OBX ones because they are graphite and dont leak like the paper or crappy metal/paper layered ones.
My turd of an 86
My turd of an 86
morgan wrote:the one in the kit will fit the header where it meets the catalytic converter. its only a little bigger for the opening, i dont think it will hurt none. youll be fine with that kit, i like the OBX ones because they are graphite and dont leak like the paper or crappy metal/paper layered ones.
so as you said the OBX kits will fit my pacesetter header where meet the cat or test pipe right?
I might still have a gasket not on my car, I'll measure if so. But yeah, it should fit fine
My turd of an 86
My turd of an 86
morgan wrote:I might still have a gasket not on my car, I'll measure if so. But yeah, it should fit fine
That would be great if you can measure your gasket before I buy them.
wouldnt it be easier to just measure your header to get the size for the cat/test gasket?...
pacesetter has a 2.25" outlet. go to a local parts store and get a $2.00 gasket.
actually I have one, brand new in the package. HMU if you too lazy to go to the parts store.
MisterJerk wrote:pacesetter has a 2.25" outlet. go to a local parts store and get a $2.00 gasket.
I did went to the autozone but they don't have them. where are you located? I saw eBay has the test pipe for sale come with 2 gaskets but like $80 it's not cheap
FDeeznuts wrote:wouldnt it be easier to just measure your header to get the size for the cat/test gasket?...
yea I did, it's 2.25" , I want to test fit but local store just don't have them, online I can't test fit I may get the wrong one.
RLZ wrote:MisterJerk wrote:I did went to the autozone but they don't have them. where are you located? I saw eBay has the test pipe for sale come with 2 gaskets but like $80 it's not cheap
East coast, VA. I got mine at pepboys, napa also has them.
heres a google link... http://www.google.com/shopping/product/2101226354477194573?q=2.25%20exhaust%20flange%20gasket&hl=en&bav=on.2,or.r_qf.&bvm=bv.44442042,d.dmg&biw=1030&bih=565&sa=X&ei=8INUUa7BJqXC4APMvYGoCg&ved=0CF0Q8wIwAQ
summit racing
http://www.summitracing.com/parts/vpe-1456/overview/
MisterJerk wrote:RLZ wrote:MisterJerk wrote:I did went to the autozone but they don't have them. where are you located? I saw eBay has the test pipe for sale come with 2 gaskets but like $80 it's not cheap
summit racing
The shape doesnt look like will completely fit, I have got one from pedboys before and it leaks.
You've measured the ID of the exhuast and it's 2.25", correct? Then all you need is any 2 bolt 2.25" exhaust gasket.
Here you go: http://vibrantperformance.com/catalog/i ... _1068_1126
You could also try local import tuner shops to see if they stock any. Any shop that specializes in Honda's or ae86's should have some in that size.
Deuce Cam wrote:You've measured the ID of the exhuast and it's 2.25", correct? Then all you need is any 2 bolt 2.25" exhaust gasket.
Yeah I will try again asking around, auto zone doesn't have it, pedboys will leaks. I might just go to muffler shop if they have some use or new.
that vibrant gasket is garbage. the metal & paper layered gaskets suck, get a graphite or copper.
i bought one of these to test out, awesome. it has a crush ring to ensure better sealing
http://www.summitracing.com/parts/sce-4 ... 4AodiWkAJA
stick with either graphite or copper, the rest will leak in a week
My turd of an 86
My turd of an 86
If you have to have the graphite gaskets go here: http://catalog.remflex.com/category_s/103.htm because those may be hard to find locally. Most of the tuner shops are going to have the cheap metal/paper 'vibrant style' gaskets.
The graphite gaskets can blow out. I've seen it happen a bunch in my Subaru days. They'll probably hold up better on a NA setup though.
RLZ wrote:FDeeznuts wrote:wouldnt it be easier to just measure your header to get the size for the cat/test gasket?...
Dude, go to autozone. Ask them to find you a two bolt gasket that is the size you need. I did that exact same thing, but ended up just buying a sheet of gasket material for $11. You can make all the gaskets you need. Also for the exhaust mani, you can get a felpro one from autozone for $12. I know because i did that exact thing.
You get what you pay for, that sheet gasket sucks a big D
My turd of an 86
My turd of an 86
