LEEN J160 6 speed for rwd "A" powered cars.
Postby oldeskewltoy » Wed Jan 16, 2013 3:17 pm
You didn't break another T50 did you?
One of the most common short comings with the AE86... and in fact ANY rear wheel drive car utilizing any of Toyota's "A" engine series... is the original T50 - the gear spacing SUCKS, they are weak (arguable), and most are well worn out. Rebuilds are costly, parts not always easy to acquire, and when you are finished you still have a T50... weak, with poor gear spacing.
So how about an upgrade...
The LEEN adapter allows the user to adapt Toyota's J160 6 speed to bolt directly on to the T50 bellhousing.
This means for more than 99% of "A" engine powered cars this could be the last transmission you'll ever need. Why do I exclude 1%? Because less then 1% of ALL "A" engines have ever made enough torque... not horsepower mind you... but TORQUE to break the J160. The J160 is EASILY capable of supporting over 200#/ft of torque in a 2800# car! That is more than double the original 4AGE torque... in a car weighing 400#s more then a fully loaded AE86 :shock:
Ok... so you want to know more.... Currently there are 3 options: 1) a minimal kit[€1292], 2) complete kit[€1815], 3) fully assembled including a USED J160 transmission - BOLT-IN READY[price dependent on transmission cost]
Pricing is in Euros... this is because the manufacturer is in Ireland. To find out how much it costs on any given day use a currency converter. Freight is additional.
Here is a view of 2 minimal kits (throwout bearing sleeve is optional)
The minimal kit consists of: main adapter, seal plate, input shaft bearing extension, 2 bearings, and a properly splined clutch disc that fits inside a stock, or stock fitting replacement pressure plate, and flywheel.
The complete kit comes with everything from the minimal kit, a very NIFTY shifter replacement assembly*, the steel throwout bearing sleeve, as well as a crossmember.
And the finished assembly.... (thanks Tony ;) ) note the shifter relocation
This is the unit I installed in my car........ note I retained the original shifter assembly
If you choose to just use the minimal kit you will need to do a bit of surgery on the tunnel, but it does fit with only minor cutting required... and the shifter is just about perfectly located once moved....
Want to read up on all of it... the original development... as well as continuing development (NOW available for the Nissan S15 version!!!)
http://gearboxconversion.com/
email your enquirers here - USA@gearboxconversion.com
gaijin_rokurunner
Re: LEEN J160 6 speed for rwd "A" powered cars.
Postby gaijin_rokurunner » Fri Jan 18, 2013 1:51 pm
Heres a few better pictures....Short shifter added and FRS/86 TRD shift Knob
htwrm
Postby htwrm » Thu Jan 24, 2013 8:38 pm
thanks a lot for posting this. i've had j160 sitting at home for 2 years now wondering what the hell i'm gonna macgyver. money's tight at the moment but i'm in for one. i'll pass my interest along to leen and maybe a deposit as well.
htwrm
Postby htwrm » Thu Jan 24, 2013 10:29 pm
btw, i cant find any info on what driveshaft to use with is converter. i have a manual driveshaft from my j160 sitting around. compared to my t50 output, it looks like they're about the same length??? please respond!
Postby oldeskewltoy » Fri Jan 25, 2013 8:50 am
htwrm wrote:btw, i cant find any info on what driveshaft to use with is converter. i have a manual driveshaft from my j160 sitting around. compared to my t50 output, it looks like they're about the same length??? please respond!
in my car (white AE71) I had the front half of the driveshaft shortened by 3/8". I would recommend that you measure for your specific application BEFORE you cut.
Here is how I measured....
With both transmissions sitting on their respective 4A/T50 bell housings, I slipped each yoke into each respective transmission
(top yoke/half driveshaft is from Mark II Supra (1982-1985) - yoke is the same as J160)
I then inserted each yoke into each transmission... found the J160 to be 3/8" longer @ the flange... and so had the shaft shortened
finally... with everything installed....
htwrm
Postby htwrm » Sat Jan 26, 2013 1:53 pm
thanks for the info
NikNes
Postby NikNes » Fri Feb 01, 2013 9:58 am
Soo cool! I wish I had the cash :)
Postby oldeskewltoy » Mon Feb 04, 2013 10:25 am
I've just gotten the information directly from LEEN...
BOLT-IN READY - €3150.00 INCLUDING freight from Ireland!!!
That price included: A) all the parts in the kit, B) the cost/and labor to machine the tailhousing to accept the shifter relocation, C) the cost for a good condition, used, J160 transmission, and finally D) the labor cost to assemble the entire unit.... AND SHIPPING! :shock:
ritz
Postby ritz » Mon Feb 04, 2013 11:42 am
Where in the US can you source a J160 from?
Postby oldeskewltoy » Mon Feb 04, 2013 12:30 pm
ritz wrote:Where in the US can you source a J160 from?
ebay :D
they are usually attached to a 3SGE BEAMS... sell for $1500-$3500....
OR you can just buy it fully assembled, ready to bolt in from LEEN ;)
ADDITIONAL places to search... JDM engine importers....
daytona350z
Postby daytona350z » Tue Mar 12, 2013 4:55 pm
i know it has been updated that this works with the s15 trans, but has anyone actually mounted this to an ae86? curious as to the shifter position since someone is selling their s15 trans locally.
thanks
LongGrain
Postby LongGrain » Tue Mar 12, 2013 5:56 pm
do they sell just the shifter relocation jobby and possibly crossmember?
would the cross member work with the beams motor fitted?
Postby oldeskewltoy » Wed Mar 13, 2013 7:44 am
LEEN is still doing testing.... but as of now to fit the S15 version - measuring, and some cutting is likely required.
The shifter kit IS available separately, it comes with instructions for your chosen machinist to follow to machine the tailhousing. Since the adapter adds about 3/4" in length, the mount will not line up.
BUT the mount is really easy to fab up. The floor is slightly different in the E7, so I fabbed a mount.
gaijin_rokurunner
Postby gaijin_rokurunner » Sat Mar 16, 2013 5:16 pm
is that bottom half from an ae86 2 piece shaft or one from your car?
Postby oldeskewltoy » Sat Mar 16, 2013 5:27 pm
gaijin_rokurunner wrote:Image
The bottom one is from my AE71...
Postby oldeskewltoy » Tue Mar 26, 2013 6:02 pm
Further developments :twisted:
We have now CONFIRMED... the S15 6th gear sets(best O/D ratio of all AZ6s)... fits on the J160 :shock:
We are hoping to swap the S15 6th onto the the RX8 box, if it goes on, that will allow a creeper 1st gear, the middle 4 gears as a close ratio set, and finally, the S15 6th to offer the maximum overdrive... the best of ALL worlds :!:
Also... in its 3rd major development, the adapter itself now fits the Mazda RX8 transmission (and so likely the Miata as well)!!
gaijin_rokurunner
Postby gaijin_rokurunner » Tue Apr 09, 2013 4:11 pm
Garage7RP
Postby Garage7RP » Mon Apr 15, 2013 12:36 pm
Can you please post gear ratio information on T50 versus the rest of the adaptable 6 speed transmissions?
Postby oldeskewltoy » Mon Apr 15, 2013 3:06 pm
Garage7RP wrote:Can you please post gear ratio information on T50 versus the rest of the adaptable 6 speed transmissions?
T50 OEM - 3.587 2.022 1.384 1.00 0.861
T50TRD1 - 2.341 1.607 1.195 1.00 0.886
T50TRD2 - 2.630 1.891 1.384 1.00 0.861
SXE10 J160 - 3.874 2.175 1.484 1.223 1.000 0.869
TRD......... - 3.106 2.175 1.585 1.223 1.000 0.869
S15 6 spd... - 3.626 2.200 1.541 1.213 1.000 0.767
NISMO....... - 2.907 1.989 1.537 1.218 1.000 0.862
RX8 6 spd... - 3.760 2.269 1.645 1.187 1.000 0.843
Miata 6-spd - 3.760 2.269 1.645 1.257 1.000 0.843
Oh.... we still aren't sure... but the FR-S likely uses a version of the AZ6 :shock:
The FR-S ratios: 3.626 - 2.188 - 1.541- 1.213 - 1.000 - 0.767
Note the FR-S gears 1st, and 3-6 are in fact the same gear ratios as the S15 :geek:
Postby oldeskewltoy » Fri May 17, 2013 9:32 am
The LEEN is published again!
Read the whole article - http://www.gearboxconversion.com/banzai.html
:D
AE25
Postby AE25 » Fri May 24, 2013 12:40 am
I remember (vaguely) reading an article on http://www.ft86club.com/ about the shift technition had changed something like 80% of the 6speed to make the short shift feel smooth.
-Mark
'71 ke26 5k, '75 ke25 4age, '78 kp60 bug, '83 ke70 3tgte, '85 ke74, '86 ae82 20v, '90 st185 gt4, '90 sw20
Postby oldeskewltoy » Sat May 25, 2013 8:15 pm
Recent install....... :shock: Just looks like it should have been there all along....... 8-)
gaijin_rokurunner
Postby gaijin_rokurunner » Sun May 26, 2013 4:10 pm
no shifter mod ?
Postby oldeskewltoy » Mon May 27, 2013 10:46 am
gaijin_rokurunner wrote:no shifter mod ?
Nope.... There is a BIG advantage to modifying the tunnel this small amount.... The shifter is PERFECTLY placed....
Here is the shifter going through its pattern in relation to the steering wheel. This is in my AE71... but the relative position is the same...
As you can see... the shifter goes from slightly in front, to slightly behind the line of the steering wheel. All within short reach, even 6th gear.
Now the negative or downside to modifying the tunnel... new carpet required. Modification of the console required. Fabrication of a cover plate for the now larger opening. And finally... loss of stealth... the relocated shifter is a dead giveaway :o
LongGrain
Postby LongGrain » Mon May 27, 2013 10:56 am
we're just about finished mounting my beams/j160, i'll post pics of where my shifter sits and how my crossmember is when its finished.
gaijin_rokurunner
Postby gaijin_rokurunner » Tue May 28, 2013 6:17 pm
I see...the throw of the short shifter i have Dan is half the travel of that video....i can literally use just my wrist to switch gears....its probably an inch up and down from neutral.....Hey Longgrain i can do carbon one piece shafts for the J160 now in the ae86 if you need a shaft...
LongGrain
Postby LongGrain » Tue May 28, 2013 7:56 pm
shoot me a PM with info/pricing and what measurements you need.
Carthik
Postby Carthik » Mon Jul 15, 2013 2:53 am
So is it 1 universal adapter that fits these different transmissions that are still in testing (J160, RX8, S15) or are there different versions of the product?
Have you done any testing with the S2000 AP1/AP2 AZ6? They are very common here in the North America and are stocked through JDM engine retailers and are quite affordable (can usually be had for 1000-1500 USD). The J160, S15 6 speed, and Miata 6 speed are quite rare.
Carthik
Postby oldeskewltoy » Mon Jul 15, 2013 10:18 pm
Carthik wrote:So is it 1 universal adapter that fits these different transmissions that are still in testing (J160, RX8, S15) or are there different versions of the product?
Carthik
There is now a single adapter that will fit ALL AZ6 transmissions.
The 1st gen S2000 does NOT use an AZ6, it is some other transmission.
Here is a view showing the Toyota(2nd down), the Mazda(3rd), the Nissan(bottom) and the S2000 is on top. Note the Toyota, Mazda, and Nissan cases all appear to be similar, now compare them to the Honda on top, the entire architecture of the transmission is completely different.
Later S2000 may have a version of the AZ6... but I seriously doubt it because the current version of the AZ6 is fitted to the FRS :shock:
Carthik
Postby Carthik » Tue Jul 23, 2013 10:03 am
The 2nd gen S2000s have the same casing or a very similar casing as 1st gens unfortunately. Multiple sources state the S2000 uses a AZ6 from Aisin, maybe it's a different style one.
I've been looking into this and RX8 6 speeds are plentiful and very cheap. How similar/dissimilar is the RX8 6 speed from the J160?
Is it possible to install the gear lever kit on the RX8 gearbox?
RX8 gearbox seems like the best way to go for the North American market. They are as cheap as $400 USD on ebay buy it now.
Cheers,
Carthik
