New and OEM 4AGE / 4AGZE 16v and 20v parts
onnaj
Postby onnaj » Mon Aug 19, 2013 7:53 am
Hello,
I have loads of brandnew oem 4AGE 16V or 20V or 4AGZE engine parts (no used parts).
Email me with a part number and i'll give you a price.
Take in mind in live in holland, so insured shipping (Worldwide) till about 2 kg's will cost around $35
onnaj
Re: New and OEM 4AGE / 4AGZE 16v and 20v parts
Postby onnaj » Thu Aug 29, 2013 8:37 am
UP!
GEOVA TRD
Postby GEOVA TRD » Thu Aug 29, 2013 8:55 am
Listing parts will definetly help ur sale cause we don't know what u have.
Thanks and have a nice day :)
onnaj
Postby onnaj » Fri Aug 30, 2013 9:01 am
I have pistons, rings, bearings, headgaskets, oil pumps, water pumps (OEM and GMB), ignition wires (OEM and other brand). You name it, i most probably have it ;)
Rogue-AE95
Postby Rogue-AE95 » Fri Aug 30, 2013 2:02 pm
Do you have any of those 10.1:1 Euro spec TVIS pistons? 18mm wrist pin? (Not to be confused with the 10.3:1 smallport pistons.)
http://forums.club4ag.com/zerothread?id=107132
onnaj
Postby onnaj » Sat Aug 31, 2013 5:44 am
Do you happen to know what part number the piston should be?
Rogue-AE95
Postby Rogue-AE95 » Sat Aug 31, 2013 6:42 am
I'm not sure if this is the right one for an 18mm wrist pin, but the part number for the .5mm oversized set is:
13103-16030
http://forums.club4ag.com/zerothread?id=7282
Don't know if the rings are the same as USDM bigport or not. Part numbers are different but who knows...
onnaj
Postby onnaj » Sat Aug 31, 2013 7:15 am
I can get the pistons with number 13103-16030. Only a few are available and they cost $335 ex shipping.
With the rings with number 13013‑16180 it'll cost $485
spoonanator
Postby spoonanator » Thu Mar 06, 2014 10:10 pm
I don't have a part number, but I have a part diagram that I circled the part I need on. I need the throttle link bracket and the link rod for a 20v Blacktop circled in the picture.
http://imgur.com/mAj6XGG
onnaj
Postby onnaj » Fri Mar 07, 2014 1:03 am
Checked toyodiy over and over again and can't find the part numbers either. I need them to check if i can order them.
Alex170984
Postby Alex170984 » Fri Mar 07, 2014 7:56 am
Don't happen to have a 16v crank pulley do you?
Cam cover gasket?
Dizzy Cap & Rotor?
onnaj
Postby onnaj » Fri Mar 07, 2014 9:00 am
Can order all. I think i might even have a 16v crank pulley.
If you need the parts please send me a pm
k3nshin3
Postby k3nshin3 » Fri Mar 07, 2014 6:48 pm
do you have 20v silvertop fuel injectors?
onnaj
Postby onnaj » Sat Mar 08, 2014 12:42 am
I have 2 sets of blacktop injectors. Don't know the condition while i bought them as a spare and never used them. Will sell for €35 a set plus whatever shipping will cost.
