Car is ae86 7age full rebuild 2k
Now this morning try to start the car and it misfire no codes then when it warms up it drives fine but when it's been sitting the whole night that's when the problem comes. But when you keep your foot on 3500 rpm sounds normal when you let go of the gas ill die
Now I'm thinking
Could be a bad afm,leaking injectors causing fuel to stay on top of piston then when it hot it burns all the fuel causing not to misfire,cold start injector,maybe new plugs haven't check will do tonight, or clean up the dizzy as its leaking abit.
New plugs
New trd wires
Injector stock
Leaking dizzy will get this fix
Misfire..in a morning
rocksteadyracer
Re: Misfire..in a morning
could maybe just get a second shift job, sorry just being a smart ass
Update shes running healthy again it was the cold start injector upon inspecting it just look at the pix you will see a white **** inside look closely
And I got it out it came out to be a white silicone sealant/rubberry thingy sorry thats what I call it.
apsogosGTi
can i ask if the engine has an oxygen sensor or a variable resistor?
So was that just stuck in there er what? Mine does the same. Ill have to check that out.
apsogosGTi
check it cause it is very important for my next answer!
Im running an o2 sensor and still using the injector resistor box.
Yes its stuck in there I dont know how it got there.
Shes running good ever since I swap the c/injector that fixed my problem
apsogosGTi
i am happy that you solved the problem..... in my engine that have no catalytic converter and variable resistor , you have to lock the idle with co mixture adjustment and spark advance
