hello everyone...
i have a corolla hatch ae92 gti european specs....
next week i will replace the oem 16v clutch flywheell with an 20v that i bought....and i was thinking maybe to replace the clutch disc with a better one.?Is it potensional or not ?thank you
proposal for a "better clutch disc"
Re: proposal for a "better clutch disc"
If you're ride is completely stock i'd stay with the OEM 20V clutch (Exedy). Seems to be very good clutches. If you're planning on tuning the engine and especially creating more torque then i'd consider using a different clutch.
onnaj wrote:If you're ride is completely stock i'd stay with the OEM 20V clutch (Exedy). Seems to be very good clutches. If you're planning on tuning the engine and especially creating more torque then i'd consider using a different clutch.
do you mean replace my oem 16v clutch disc with an oem 20v clutch disc?if yes does it fit?
If you use the 20V flywheel, the 20V clutch would fit ofcourse.
nice ride btw, the 130HP 4AGE!
onnaj wrote:If you use the 20V flywheel, the 20V clutch would fit ofcourse.
thank you mate!these are older moments...new stuff is coming soon
The 2ZZ-GE clutch will also fit, and is a heavier pressure plate from the factory for the higher power output of those engines.
Jeff
Jeff
Jeff Lange wrote:The 2ZZ-GE clutch will also fit, and is a heavier pressure plate from the factory for the higher power output of those engines.
I am interested when changing gears to keep higher rpms...
Jeff
I've got the 2ZZGE clutch kit on my AW11 and it's fine. Rated for up to 225hp
Amazing what clutch kits fit older cars
Alex170984 wrote:I've got the 2ZZGE clutch kit on my AW11 and it's fine. Rated for up to 225hp
whats the size of the 2zzge ?is it stronger than the 16v ?
Which flywheel? 2zzge flywheel, clutch and PP? on a 4age?
Blacktop flywheel...and oem clutch plate 16v
I think the 20v flywheel is different so you will have to replace the pressure plate and disc no matter what. If it's a street car I'd consider something full face.
I liked my friend's centerforce dual friction, but you will have to determine if they ever offered those with a 20v.
krammit the frog wrote:I think the 20v flywheel is different so you will have to replace the pressure plate and disc no matter what. If it's a street car I'd consider something full face.
my clutch disc is 212mm so i can use it with bt flywheel
I've got a 16v Fidanza flywheel
The 2ZZGE clutch fits the 16v components
Don't know if the clutch is any stronger, i've not run my engine in long enough to test it out properly.
i will finally use my 16v clutch with the 20v flywheel. I will balance these items first
