LEEN J160 6 speed for rwd "A" powered cars.
Re: LEEN J160 6 speed for rwd "A" powered cars.
Postby oldeskewltoy » Tue Jul 23, 2013 10:21 am
Carthik wrote:The 2nd gen S2000s have the same casing or a very similar casing as 1st gens unfortunately. Multiple sources state the S2000 uses a AZ6 from Aisin, maybe it's a different style one.
I've been looking into this and RX8 6 speeds are plentiful and very cheap. How similar/dissimilar is the RX8 6 speed from the J160?
Is it possible to install the gear lever kit on the RX8 gearbox?
RX8 gearbox seems like the best way to go for the North American market. They are as cheap as $400 USD on ebay buy it now.
Cheers,
Carthik
The RX8 gearbox is nearly the same as the Miata version... the only real difference is the tail housing on the RX8 is shorter, and the shifter placement makes modifying the tunnel almost the same job as it is for the J160 version.
Photo below is an RX8 transmission fitted to the S15 Silvia bellhousing/front cover
So... to answer the first part of your question... as long as the RX8 trans looks like the one in the photo... YES , our adapter will fit it. To answer your second question, the shifter kit we manufacture only fits the J160 because the J160 has an area we can mount the shifter too (the original shifter mounting holes). The tail housing for the RX8 is different, and so our shifter doesn't fit...
With that said... the RX8 shifter location will be similar placement as it is in my car... the tunnel will need to be modified, but overall it should work!
Postby oldeskewltoy » Tue Jul 23, 2013 4:35 pm
Believe it or not.... Generation 3 has arrived! Tough to believe but LEEN has finished the 3rd production run on this, the newest version now fits ALL AZ6 transmissions. :o :o :o
As we all learned above... RX8* versions of the AZ6 are selling for as little as $400... add our adapter, move your shifter hole back to about where mine and Jesse's is... and for under $2500 (LESS then the cost of a rebuilt T50 w TRD gears!) you can be rowing 6 speeds instead of 5.... :twisted:
RX8 6 spd... - 3.760 2.269 1.645 1.187 1.000 0.843
T50 OEM.... - 3.587 2.022 1.384 1.00 0.861
T50TRD1.... - 2.341 1.607 1.195 1.00 0.886 - (pricey set - about $2000)
T50TRD2.... - 2.630 1.891 1.384 1.00 0.861 - (cheaper set - about $1400)
Postby oldeskewltoy » Tue Oct 08, 2013 9:26 am
I want to thank our newest client......... :mrgreen:
This LEEN will be behind a Hasselgren built 4AGE :shock:
gxdivider
Postby gxdivider » Mon Oct 21, 2013 4:27 pm
Just wondering how many are available.... Plan on picking one up New Year's thereabouts.
Postby oldeskewltoy » Tue Oct 22, 2013 4:12 pm
gxdivider wrote:Just wondering how many are available.... Plan on picking one up New Year's thereabouts.
As of now there is no reason we shouldn't be able to deliver... As far as production examples... C.A.D. is a lovely thing... :D LEEN plugs in their specifics, and out pop finished components. I believe the longest wait do far was a client who waited 6 weeks.
Typically... payment is made, and 2 to 4 weeks later we send you a notice of shipment.
gxdivider
Postby gxdivider » Tue Oct 22, 2013 5:34 pm
Thanks. I was just concerned there isn't enough interest to warrant continuing production.
Postby oldeskewltoy » Wed Oct 23, 2013 9:21 am
gxdivider wrote:Thanks. I was just concerned there isn't enough interest to warrant continuing production.
plenty of interest...... :D AND enough volume to continue production....
What you might not realize... is this adapter also opens up Toyota engine swaps into the MX5... imagine if you will a 270hp, 10,000 rpm Miata on the track............ :o :o
8-)
SolidSTI
Postby SolidSTI » Wed Oct 23, 2013 11:08 am
Are there any plans to build a shifter setup for the RX8 transmission for those of us that wouldn't want to cut our tunnel or console?
http://TruFactsRacing.com
Postby oldeskewltoy » Thu Oct 24, 2013 3:50 pm
SolidSTI wrote:Are there any plans to build a shifter setup for the RX8 transmission for those of us that wouldn't want to cut our tunnel or console?
I'll ask........ ;)
MEGA86
Postby MEGA86 » Sun Feb 02, 2014 2:19 am
I'd also be interested if they made the gear lever kit for the RX-8 transmission. Without it, it would probably be too close to the hand brake lever.
Postby oldeskewltoy » Sun Feb 02, 2014 8:04 am
As of now there still isn't a relocated shifter available for the RX8 version of the AZ6.
Concerning your other point..... I shortened mine by about 1 3/4"
Postby oldeskewltoy » Wed Feb 12, 2014 8:23 am
UPDATE:
As if this couldn't get ANY easier.... Joe has done some research....
email from LEEN wrote:Hi Dan,
The OEM Toyota clutch disk with the spline pattern to match the J160 gearbox.
200mm OD: Toyota Part No.: 31250-28142
212mm OD: Toyota Part No.: 31250-28122
These absolutely definitely fit.
LEEN
You now have OEM Toyota discs to fit your swap..... :mrgreen:
ZINCHOTRAN
Postby ZINCHOTRAN » Sat May 31, 2014 6:19 pm
Dumb question.
How about an FR-S transmission into an AE86??
Postby oldeskewltoy » Sun Jun 01, 2014 11:54 am
ZINCHOTRAN wrote:Dumb question.
Not so dumb......... ;)
The cost of an FR-S version of the AZ6 is still too expensive to see if the bolt pattern is the same... or not. It... MAY match the bolt pattern, right now the only ones who actually know that are the Aisin, Subaru, and Toyota engineers... The FR-S version does have one significant advantage over the J160... the FR-S version has a reverse lockout that the J160 does not. :!:
asyrigos
Postby asyrigos » Tue Jul 08, 2014 11:23 am
Quick question for those that have installed the J160 in the AE86:
I got the geabox mounting bracket from Joe@Leen but there is no poly bushing to be installed between the gearbox and the mount.
How did you get around this? Without a bushing the friction between the gearbox metal & the mounting bracket will be an issue.
Thx
Postby oldeskewltoy » Tue Jul 08, 2014 12:11 pm
asyrigos wrote:Quick question for those that have installed the J160 in the AE86:
Thx
Got any photos?? In my install I used the OEM J160 rubber mount, but I also built my own cross member
asyrigos
Postby asyrigos » Tue Jul 08, 2014 12:32 pm
Thx for the quick reply. Going to the shop tomorrow to snap pics.
Has anyone tried to use the AE86 rubber mount? I was told by the shop will not fly....
Postby oldeskewltoy » Tue Jul 08, 2014 1:06 pm
asyrigos wrote:Thx for the quick reply. Going to the shop tomorrow to snap pics.
The OEM T50 mount fits entirely differently, as your shop says it will not work. I believe the W58 mount MAY fit... not sure but have heard a few rumors to that affect
Postby oldeskewltoy » Wed May 06, 2015 9:58 am
I've not had contact with Joe for about 4 months, and a short time ago the LEEN webpage and Facebook page were taken down.
MEGA86
Postby MEGA86 » Fri May 29, 2015 10:01 pm
If you get a hold of them, let me know. I want to order a full kit.
gxdivider
Postby gxdivider » Sun Jun 14, 2015 11:04 pm
Well it's only been 1.5 yrs but I finally got my **** together. So I go and look up the Leen conversion and I find out the website is down.
Put me on the waiting list if there is one.
gildardo
Postby gildardo » Wed Jul 22, 2015 8:11 pm
Would anyone here have the pdf files of the installation instructions for the shiffter relocation. I have the kit, missing the instructions.
thanks gil.
Postby oldeskewltoy » Thu Jul 23, 2015 8:27 am
gildardo - check your PM
gxdivider (and everyone else) - I'm working on it.....
gxdivider
Postby gxdivider » Sun Aug 16, 2015 7:25 pm
MONITORING
