If you're looking to do an axel swap in your E chassis or put an Ey type multilink axel under a different car, you'll want these axel brackets to do the job. If you're thinking about cutting off a set of stock brackets and re-using them, you can be in for a fair bit of work. When you get them cut off, the brackets are old, rusty, cut up and no longer match the shape of the axel tubes and often times have suspension mounting holes that are no longer round and you will still need to buy geometry correction brackets.
These all new brackets are CNC cut from 1/8" (3mm) steel then formed to work with stock type suspension components. We've also made them with multiple geometry correction points already built in so you won't need to buy bolt on correction brackets as well. We've also maintained the stock mointing points to keep the hardware legal for sanctioning bodies that require stock mounting geometry. The set comes with 2 new upper mounts, 2 new lower mounts with new shock mounts that have been relocated inward for more tire clearance and a new Panhard mount with all required hardware.
This set is for 2.5" to 2.6" diameter axels. (3" axel dia. also available)
Want just upper or lower mounts? Send us an email for a price quote on only the parts you need.
$153 per set
[url="http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=51&step=4&pid=370"]http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=51&step=4&pid=370[/url]
