New Set of Borg Warner Fuel Injectors for ae86 Gts model $110 including shipping
New Distributor with new rotor button and new cap never installed $110 Sold
New Mass Air Flow Sensor Meter $115 including shipping Sold
New oem Toyota EGR Valve never installed $230 including shipping
Oem ae86 corolla gts hatchback Driveshaft in great condition $225 including shipping
New oem Toyota Throttle Position Sensor never installed $115 including shipping
Injen Short Ram Cold Air Intake bought in Mar 2015 in excellent condition $130 SOLD
New oem Toyota Idle Air Control Valve never installed $175 including shipping SOLD
Wiper Motor in great condition $35 including shipping Sold
Rear Speaker Pod Enclosures with speaker wire harnesses for hatchback $100 shipped
Whiteline Adjustable Rear Lateral Panhard Bar only 9 months old $80 including shipping Sold
New Power Brake Booster $85 including shipping SOLD
Front set of oem uncut Struts with spindles in great condition $275 including shipping
GTS Hood white in color in good shape $160 including shipping
Rack and Pinion for power steering only 4 months old $150 including shipping Sold
Cam gear cover in great condition $25 including shipping Sold
Fuel tank filler neck in great condition $35 including shipping Sold
Injector resistor plug in great condition $23 including shipping Sold
MAF vacuum switching valve in great condition $35 including shipping Sold
A/C compressor mount bolts brand new $8 including shipping
All four rear suspension links, rear strut bar with poly bushings and panhard bar $110 Sold
Heater Core in good condition clean and not clogged $50 including shipping Sold
New Lebra kit (4 piece for hood, bumper, and headlights)$40 including shipping Sold
Fan clutch assembly (will throw in extra fan clutch free) $25 including shipping Sold
Rear liscence plate lights was $30 now $25 Sold
OEM radio (radio works but never used cassette)$45 Sold
Fuse block cover $15 Sold
Driver/Pass door handles $20 each Sold
Digital clock $18 Sold
Front dash cover $40 Sold
Oem snorkel air hose $25 Sold
door handle inside trims $8 each Sold
Wire Harness $40 including shipping Sold
Oem tail lights without harness/bulbs and both also cracked for $35 Sold
Driver/Pass doors was $65 each Sold!
Dash climate control bezel $20 Sold
Fan shroud $45 Sold
Front Strut Bar $35 shipped SOLD
C Pillar Bar $35 shipped SOLD
Complete Perfomance Exhaust with silencer(not pictured) only 7 months old with Magnaflow high flow converter in great condition $130 including shipping
Aftermarket Header only 6 months old in great condition $145 including shipping Sold
White usdm bumper in great condition with foam $55 shipped Sold
White bumper side pieces $28 including shipping Sold
Front bumper metal reinforcement in great condition $100 Sold
T50 transmission w/o bell housing $100 Sold
4ac cylinder head with rocker arm w/o camshaft $30 including shipping Sold
Stock front sway bar with poly bushings(will need to be installed) $35 Sold
Stock rear sway bar with poly bushings $27 including shipping Sold
Stock panhard lateral rod $25 including shipping Sold
Front grill $25 Sold
Like new brake master cylinder reservoir cap cover $18 Sold
A/C idle up valve assembly $23 sold
Driver/Pass front seat head rests was $28 total including shipping for both Sold
stock rearview mirror $12 Sold
Front and rear speaker covers $15 each Sold
Front dash ash tray $10 including shipping Sold
Both engine bay and inside fuse blocks with wire harnesses $45 each Sold
Passenger side quarter panel $35 Sold
driver/pass side view mirrors $30 each Sold
Rear side marker lights was $15 include shipping Sold
Window cranks $7 each including shipping
Brand New A/C condensor never installed $67 including shipping
An extra T50 transmission shifter $20 Sold
Sideview mirrors inside covers $7 each including shipping Sold
Climate control meter $30 Sold
Used climate control meter cables(all 4 of them) $18 including shipping for all 4
Headlight motors $15 each SOLD
Oil pump with new gasket in great condition $20 including shipping
Instrument cluster gauges white face covers $10 including shipping Sold
pass door hinges $24 including shipping Sold
Front grill oem toyota emblem $7 including shipping
Headlight eyelids $25 for set Sold
Oem metal front coolant pipe with sensor $25 including shipping Sold
Egr modulator $14 including shipping Sold
A/C Evaporator Core $30 including shipping Sold
Long A/C Line(from firewall) $45 including shipping
Climate meter control switch $8 including shipping Sold
Climate meter electric plug in with light $8 including shipping
Dash/Cluster Harness $25 including shipping Sold
Stock oil temp pressure sending unit $8 including shipping Sold
Fuel injector wire harnesses with plugs and clips and cold injector harness (I have two sets of these) $25 including shipping each set or $35 including shipping both sets
Two Super stock Accel chrome igniton coils in excellent condition $13 each Sold
OEM service manual for glove compartment $17 including shipping Sold
Interstate Mega Tron ll Battery $47 including shipping Sold
MSD 6a ignition box in like new condition $125 including shipping Sold
Brand new MSD 8910-EIS for Tachometer adapter for Toyotas $40 including shipping Sold
Fog Switch $16 including shipping Sold
Gas tank in good shape clean with no leaks or rust and practically new fuel pump with bracket all for $200 including shipping anywhere Sold
Complete antennae assembly $10 including shipping Sold
Also selling a set of practically new wheels and new tires in excellent shape $620 Sold
Oem Temperature Sensor $7 including shipping Sold
Denso Oxygen Sensor with Gasket Sold
Pair of stock white front fender trim $20 including shipping Sold
Oem cigarette lighter $5 including shipping Sold
Oem center console lid cover $10 including shipping Sold
Driver and passenger door powered sideview mirror harnesses $20 including shipping Sold
Driver and pass. door bottom weatherstrip seal with snap on clips $22 including shipping megan lowering springs front and rear Sold
Front brake calibers Sold
Rear brake calibers Sold
Exterior door key lock $8 including shipping Sold
Practically new starter $55 including shipping Sold
classic pacer center rim caps(only two left) $10 including shipping
Harness plugin for inside dash $8 including shipping Sold
Headlight motor harness plug $8 including shipping Sold
Wiper switch harness pigtail plug in $8 including shipping Sold
New performance headlights $20 for all four including shipping Sold
Oem fuse block relays $7 each including shipping Sold
Oem Flasher relay $35 including shipping
Oem blower relay $10 including shipping Sold
Set of front and rear rotors (recently turned) $45 including shipping Sold
Front signal light lens cover $8 including shipping Sold
Random harness plugins $10 including shipping Sold
Oem rear speaker harness plugs $14 including shipping
Front park light plug $7 including shipping Sold
Fuel injection cold start valve $20 including shipping Sold
Complete new A/C system with all major components $400 including shipping Sold
Power steering pressure line assembly $25 including shipping Sold
Like new Kyb GR-2 excel front shock cartridges $54 including shipping Sold
Brand new JVC double din 6.1 inch screen dvd/cd player with many features such as bluetooth,
navigation app, usb port, etc. still sealed in box $200 including shipping Sold New euro style tail lights with chrome lens $110 including shipping SOLD
Driver or pass. door sleeve boot $8 including shipping Sold
Headlight retractor relay $27 including shipping Sold
Two fusible link cap covers(exterior painted blue) $8 each including shipping
center console rear ash tray $10 including shipping Sold
